Drilling a hole in Aluminum Rib; how close?
Old October 14th 07, 11:32 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Drilling a hole in Aluminum Rib; how close?
I'm trying to align the holes in the leading edge sheetmetal with the
existing holes in the ribs. Sometimes they line up, sometime I can see
the hole in the rib, maybe 1/2 screw shank thickness away (in which
case I use a Dremel bit to enlarge the hole in the sheetmetal in the
direction of the rib hole) and in some cases I'm more than a screw
shank's distance away, so I'm going to have to drill another hole in
the rib. Question is how close can screw holes in ribs be before I've
weakened the rib?
If this were wood I'd enlarge the hole, glue in a dowel and redrill
the hole. What's the equivalent when drilling holes in ribs? - MikeH
Old October 14th 07, 06:24 PM posted to rec.aviation.homebuilt
weakened the rib?
Typically two diameters from the edge of the sheet. If you got
the hole too close, I suppose you'd need to rivet a strip into the rib
flange and redrill.
Which airplane uses screws to attach sheet metal? Is this a
Champ?
Riveting info that would generally apply, I think, to screw
holes is found on page 4-20 of this link:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2004.pdf
Dan
Old October 15th 07, 01:59 AM posted to rec.aviation.homebuilt
Darrel Toepfer
Which airplane uses screws to attach sheet metal? Is this a Champ?
My Pacer does, so would the 3Pacer...
Old October 15th 07, 02:13 AM posted to rec.aviation.homebuilt
Don Lewis
"Darrel Toepfer" wrote in message
. 18...
Luscombe also............
Old October 15th 07, 09:09 PM posted to rec.aviation.homebuilt
Michael Horowitz
T'craft - Mike
weakened the rib?
flange and redrill.
Champ?
Dan
Worm Hole no Need for Black Hole Michael Baldwin, Bruce Products 2 May 8th 07 11:04 AM
misdrilled hole on on tubular aluminum spar question patrick mitchel Home Built 12 October 2nd 06 08:17 PM
Drilling a solid crankshaft Ole Moyer Home Built 8 November 2nd 05 05:17 AM
Drilling holes in steel tubing wright1902glider Home Built 20 October 9th 05 03:43 AM
Thanks for ideas on drilling a centered hole! Scott Home Built 12 October 25th 04 02:52 AM
