Replacing Interior Glider Pockets?
Old August 26th 09, 10:28 PM posted to rec.aviation.soaring
ContestID67[_2_]
Default Replacing Interior Glider Pockets?
I own a DG and the interior pockets are quickly becoming less like
pockets and more like tubes without bottoms...if you know what I mean.
So I am planning a winter project to replace these pockets. I can sew
but a few questions leap to mind;
1) What material are pockets typically made of? Anything special that
I won't find at the local sewing shop?
2) What is used at the top of the pocket to make it stretchy.
3) The pocket is attached to a long piece of matching material along
the interior. I assume that this long piece has some stiff material
inside to give it rigidity. What is it?
4) I assume that the old pocket is glued to the wall of the glider.
Any tricks in removing this?
5) What do I use to attach the new pocket to the wall of the glider?
Thanks in advance for your suggestions. As always I will photograph
my results and put them on my web site. http://aviation.derosaweb.net.
- John DeRosa
Old August 26th 09, 10:40 PM posted to rec.aviation.soaring
Chris Reed[_2_]
My seamstress qualifications are roughly nil, but from the gliders I've
flown in I'd suggest:
Pretty much anything you like, from leather to orange velour.
Leatherette/vinyl seems popular.
Elastic. Sew the hem of pocket front with the elastic inside, stretch
elastic, sew elastic to the seams at either end of the pocket (this is
from my mother's method of making elasticated waist skirts for my
sisters back in the '60s - then it was known as "knicker elastic").
Anything from cardboard to spring steel. I'd suggest a piece of thin
plastic (ice-cream tub?).
Brute force I think, though maybe a sharp knife eased along the join
would help.
Glue velcro to side wall and pocket - that way you can make new pockets
when these wear out. Latex-based glue (brand name Copydex in the UK) is
good for fabric to fabric joins.
Old August 27th 09, 04:40 AM posted to rec.aviation.soaring
Frank Whiteley
1) What material are pockets typically made of? *Anything special that
the interior. *I assume that this long piece has some stiff material
inside to give it rigidity. *What is it?
would help.
There are velcros, then there are velcros. Some are rated at 100
peels, others at 10,000 peels. For greater holding power in the
glider cockpit, I recommend 3M dual-lock. Not cheap, but at least 5X
the holding power of the best velcro. Good for pockets, PDA's, and
what have you.
Frank Whiteley
Old August 27th 09, 09:55 AM posted to rec.aviation.soaring
Cats
So I am planning a winter project to replace these pockets. *I can sew
Thanks in advance for your suggestions. *As always I will photograph
my results and put them on my web site. *http://aviation.derosaweb.net.
- John DeRosa
You want to use something hard-wearing for the pocket, which means an
ordinary domestic sewing machine might have problems sewing it. An
old Singer would be the beast for the job - my mother used to use one
for heavy-duty stiching. It also produces a very nice stitch. The
pockets in mine look to be made of moquetet, as does the seat pad
cover. I think they are original and the glider is 20 years old.
It's also used in the UK for seat coverings in buses and so on, though
getting some might be harder than other stuff. However hard-wearing
upholstry material should be long-lasting. Also use stronger elastic
than knicker elastic. If you use strong elastic but don't stretch it
much you should get a satisfactory result - weak elastic stretched a
lot has a short life. Consider putting pleats in the pocket at each
end and/or the bottom to increase the volumn of the pocket. Don't
skimp on the seam allowances and overcast the edges in some way. Even
Copydexing them would be better than leaving them raw.
I have seen gliders with the pockets screwed to the cockpit wall but
it would be obvious if yours was done that way.
Old August 27th 09, 10:31 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Thu, 27 Aug 2009 01:55:29 -0700, Cats wrote:
I have seen gliders with the pockets screwed to the cockpit wall but it
Mine came with a premade pocket, about 300mm x 100mm with a zipper and
looking as if it was made to carry pens, etc in a schoolbag. Its just
big enough to hold a pen, two rolls of wing tape and a few freeezer bags
and is held on the sidewall with 4 x 25mm Velcro patches, but thats
barely adequate to keep it in place. A continuous Velcro 12-15mm strip
along the top and bottom would be better.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 27th 09, 04:27 PM posted to rec.aviation.soaring
Dr. John Ackerson
I purchased a car visor storage case from the local auto parts store
for only $10. I cut off the straps and attached a strip of Velcro on
the back. It's not very big for holding bulky items but holds my
map, candy bar and O2 cannula very nicely.
Old August 27th 09, 08:18 PM posted to rec.aviation.soaring
Tim Ward[_1_]
"Dr. John Ackerson" wrote in message
Yes, before you go to the trouble of sewing your own, check out the "trunk
organizers" available at Wal-Mart and auto parts stores. You may find
something that needs minimal modification to work well.
The one in my 1-26 was ten dollars, and it's got lots of pockets.
Tim Ward
Old August 28th 09, 02:56 PM posted to rec.aviation.soaring
Paulus[_2_]
On Aug 27, 3:18*pm, "Tim Ward" wrote:
"Dr. John Ackerson" wrote in ...
the back. * It's not very big for holding bulky items but holds my
organizers" available at Wal-Mart and auto parts stores. *You may find
Tim Ward
Or, a used ladie's purse bought at the Goodwill store for 1$. Pick a
suitable size.
A Gucci for the well heeled.
Paul
Old August 28th 09, 03:44 PM posted to rec.aviation.soaring
Nine Bravo Ground
-- Mine is leather, but I think a sturdy upholstery fabric might work
too.
-- I think this has been covered - stretch a piece of elastic inside
the rolled-over top lip of the pouch and stitch the ends together. The
"draw string" effect should keep the opening of the pouch tight
-- I suspect steel or a composite material. You could use either.
-- Mine is attached using three snap fasteners so I can remove it when
I choose. One half of each snap is glued to the cockpit wall and the
other half to the "stiff material" you mention in #3 that holds the
outside edge of the pocket stiff.
-- Pulling or careful cutting with a blade of some sort. Use your
judgement.
-- Snaps or velcro depending on what seems to best suit the
application
9B
What glue to use for replacing cockpit interior fabric Gary Emerson Soaring 11 February 8th 08 06:13 PM
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 04:54 PM
Replacing com antennas Mike Noel Owning 9 May 11th 06 03:28 PM
Pirep on replacing interior plastic parts [email protected] Owning 1 April 12th 05 05:06 AM
Replacing Battered POH Marco Leon Owning 14 February 17th 04 08:38 PM
