Effect of weight on the Polar
Old October 15th 09, 10:55 PM posted to rec.aviation.soaring
Pawnee Pilot[_2_]
Default Effect of weight on the Polar
If I have 2 polars for the same glider, say at 28kg/m2 vs 43kg/m2,
the polar for the heavier glider is displaced to the right and down.
Applying the square root of the ratio of the wing loading, ie sqrt
(43/28), would give the higher speed for the increased loading, what
is displacing the polar down? Is it just the additional profile drag
at the higher speed?
Old October 16th 09, 03:32 PM posted to rec.aviation.soaring
mattm[_2_]
On Oct 15, 5:55*pm, Pawnee Pilot wrote:
If I have 2 polars for *the same glider, say at 28kg/m2 vs 43kg/m2,
No, I believe it's the higher induced drag since you have to fly at a
higher angle of attack to generate more lift of offset the wing
loading.
To see exactly what it does to the polar multiply the x and y value
for each point by sqrt(w1/w0). At higher speeds the actual sink
rate should be less -- this is the advantage that ballast gives you.
-- Matt
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 04:24 PM
K8 Polar Mike Schumann Soaring 2 July 22nd 06 04:10 PM
Looking for ASW-15B polar with weight [email protected] Soaring 3 April 24th 06 12:28 AM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
