PDA to Volkslogger declaration?
I've been searching for an hour or so now, and can't find an answer.
Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? TIA |
Naviter's ConnectMe application does that:
http://www.naviter.si/products/connectme.php?Itemid=62 Cheers, Lars Peder DG-600 EE, Denmark "Uncle Fuzzy" wrote in message ... I've been searching for an hour or so now, and can't find an answer. Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? TIA |
Użytkownik Uncle Fuzzy napisał:
Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? ConnectMe: http://www.naviter.si/products/connectme.php?Itemid=62 -- WojtuÅ›.net |
On Nov 18, 11:38Â*am, Wojciech Scigala wrote:
Użytkownik Uncle Fuzzy napisał: Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? ConnectMe: http://www.naviter.si/products/connectme.php?Itemid=62 -- Wojtuś.net Thank you. I will try it this weekend. |
If the instructions are clear and work first time with the application
you are going to use, fine – ignore what follows. I use Winpilot, which has this facility, but I spent ages fruitlessly seeking out how to do it. Eventually I found that you set up the declaration you want in WP; connect the VL; set VL to “PC” mode; in effect download the existing VL declaration to WP; then exchange it for the new WP declaration that you really want. Maybe that logic will help you take less time than I took to learn how. Chris N. |
On Nov 18, 2:30*pm, Uncle Fuzzy wrote:
I've been searching for an hour or so now, and can't find an answer. Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? TIA Pocket*Strepla is free and very intuitive. I use it from IPAQ 3950 to Volkslogger with no problems. Also, you can download the flight logs from the VL using it. It's at strepla dot de. I've used it for a couple of years - it's bulletproof (and I'm a techno-bozo). Dan |
On Nov 19, 1:18*pm, Dan wrote:
On Nov 18, 2:30*pm, Uncle Fuzzy wrote: I've been searching for an hour or so now, and can't find an answer. Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? TIA Pocket*Strepla is free and very intuitive. *I use it from IPAQ 3950 to Volkslogger with no problems. *Also, you can download the flight logs from the VL using it. It's at strepla dot de. *I've used it for a couple of years - it's bulletproof (and I'm a techno-bozo). Dan Pocket*Strepla isn't free anymore. |
On Nov 19, 5:29*pm, mattm wrote:
On Nov 19, 1:18*pm, Dan wrote: On Nov 18, 2:30*pm, Uncle Fuzzy wrote: I've been searching for an hour or so now, and can't find an answer. Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? TIA Pocket*Strepla is free and very intuitive. *I use it from IPAQ 3950 to Volkslogger with no problems. *Also, you can download the flight logs from the VL using it. It's at strepla dot de. *I've used it for a couple of years - it's bulletproof (and I'm a techno-bozo). Dan Pocket*Strepla isn't free anymore. VL to IGC works great. Available from Cumulus Soaring. |
Hi,
I think he meant pocket*StrePla-Connect - which I believe is free. Paul Remde "mattm" wrote in message ... On Nov 19, 1:18 pm, Dan wrote: On Nov 18, 2:30 pm, Uncle Fuzzy wrote: I've been searching for an hour or so now, and can't find an answer. Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? TIA Pocket*Strepla is free and very intuitive. I use it from IPAQ 3950 to Volkslogger with no problems. Also, you can download the flight logs from the VL using it. It's at strepla dot de. I've used it for a couple of years - it's bulletproof (and I'm a techno-bozo). Dan Pocket*Strepla isn't free anymore. |
On Nov 19, 11:26*pm, "Paul Remde" wrote:
Hi, I think he meant pocket*StrePla-Connect - which I believe is free. Paul Remde "mattm" wrote in message ... On Nov 19, 1:18 pm, Dan wrote: On Nov 18, 2:30 pm, Uncle Fuzzy wrote: I've been searching for an hour or so now, and can't find an answer. Is there a utility that runs on a PDA (iPAQ 3850, PPC2002) that allows uploading a delcaration to a Volsklogger? TIA Pocket*Strepla is free and very intuitive. I use it from IPAQ 3950 to Volkslogger with no problems. Also, you can download the flight logs from the VL using it. It's at strepla dot de. I've used it for a couple of years - it's bulletproof (and I'm a techno-bozo). Dan Pocket*Strepla isn't free anymore. Oops - meant, as Paul says. PS-connect. Mea culpa. |
Similar Threads | ||||
NEW Declaration Requirements | Judy Ruprecht | Soaring | 19 | October 1st 09 02:46 PM |
Electronic declaration - Colibri | Ian Cant | Soaring | 2 | September 6th 06 05:55 PM |
Electronic declaration | tango4 | Soaring | 12 | June 24th 04 08:34 AM |
Electronic declaration (for Volkslogger) | stephanevdv | Soaring | 0 | June 23rd 04 11:54 PM |
Help needed with task declaration | Stewart Kissel | Soaring | 2 | March 23rd 04 05:43 PM |
