radio interference
Old April 29th 10, 12:02 AM posted to rec.aviation.soaring
ryanglover1969[_2_]
Default radio interference
I have a question for all the electronically minded pilots out there.
Every time I transmit my vario goes crazy. The funny thing is that
when the colibri and or the Ipaq isn't connected it doesn't go crazy.
My set up is as follows: LX 1600vario
Dittle FSG 2T radio
Colibri data logger
Ipaq 3600 running SeeYou mobile
What's the solution? I got some ferrite beads and put them in various
locations with no success.
should I shield the cables from the vario to the colibri and Ipaq???
Old April 29th 10, 12:52 AM posted to rec.aviation.soaring
GM
* * * * * * * * * * * * * * * * * * Dittle FSG 2T radio
* * * * * * * * * * * * * * * * * * Colibri data logger
* * * * * * * * * * * * * * * * * * Ipaq 3600 running SeeYou mobile
Ryan,
have you checked the stability of your power supply? I run a very
similar set-up: Becker 3201, LX20, LX1600 and an iPAQ but have a very
good battery. Place a digital voltmeter between and a digital ampere-
meter inline (both with min.-max hold function) with the power leads
and key the microphone. There is a good chance that the power supply
collapses momentarily below the minimum required to run everything
properly.
Uli
Old April 29th 10, 02:07 AM posted to rec.aviation.soaring
Brian Whatcott
Dittle FSG 2T radio
Colibri data logger
It's just possible I suppose, that the cables from the colibri and/or
Ipaq are resonating in the VHF - if their length is about 23 or 46
inches: if so, shielding or loading them might help.
Brian W
Old April 29th 10, 03:31 AM posted to rec.aviation.soaring
Paul Remde
Hi,
GPS data cables can be quite noisy electrically. That is why all Goddard
cables are shielded. I've never had a customer complain about electrical
noise with a Goddard cable or the PS-5a power converter.
http://www.cumulus-soaring.com/goddard.htm
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"ryanglover1969" wrote in message
Dittle FSG 2T radio
Colibri data logger
Old April 29th 10, 02:56 PM posted to rec.aviation.soaring
Paul Remde
Hi,
On a related subject. I have a customer with a new TruTrak Pictorial Turn
and Bank that is complaining of noise on the radio when the unit is turned
on. I've sold a fair number of these units with no previous complaints.
The unit has only 12V power connections -so there are not GPS RS-232 data
signals to make noise. Has anyone else had any electrical noise issues with
this product? Any suggestions? My guess is that his radio antenna or other
radio wires are poorly shielded and/or running past the TruTrak unit. Or
the TruTrak's power leads are putting noise into the radio antenna. The
unit has a small motor inside.
The manufacturer suggested sending it back to them for warranty repair. But
they didn't sound like they were confident that they could fix the problem.
Best Regards,
Paul Remde
"Paul Remde" wrote in message
Hi,
Best Regards,
Paul Remde
Dittle FSG 2T radio
Colibri data logger
Old April 29th 10, 03:54 PM posted to rec.aviation.soaring
Darryl Ramm
On Apr 29, 6:56*am, "Paul Remde" wrote:
Hi,
On a related subject. *I have a customer with a new TruTrak Pictorial Turn
on. *I've sold a fair number of these units with no previous complaints..
signals to make noise. *Has anyone else had any electrical noise issues with
this product? *Any suggestions? *My guess is that his radio antenna or other
radio wires are poorly shielded and/or running past the TruTrak unit. *Or
the TruTrak's power leads are putting noise into the radio antenna. *The
The manufacturer suggested sending it back to them for warranty repair. *But
Best Regards,
Paul Remde
Hi,
GPS data cables can be quite noisy electrically. *That is why all Goddard
cables are shielded. *I've never had a customer complain about electrical
Best Regards,
Paul Remde
* * * * * * * * * * * * * * * * * *Dittle FSG 2T radio
* * * * * * * * * * * * * * * * * *Colibri data logger
* * * * * * * * * * * * * * * * * *Ipaq 3600 running SeeYou mobile
The first suspect should always be coupling through the power supply,
put a ferrite toroid or choke on the line right near the device
suspected of causing the noise, or as a test power it from a separate
battery and see if the problem is still there, if it is then it's RF
coupling not via the power supply. If it is not the powerr supply then
check cable/wiring routing, coax connectors and coax and wiring
shielding.
To be clear, since the TruTrak uses a solid state gyro, it does not
contain a motor to spin a gyro. The "motor" may mean the mechanism to
move the display background. That all may be irrelevant and the issue
if there is one from the unit may be simply RF noise from digital
electronics.
Darryl
Old April 29th 10, 09:44 PM posted to rec.aviation.soaring
John Smith
I don't know the TruTrak, but I suspect it uses an oscillating piezo
crystal, which implies a pretty high frequency electronic circuit, which
might or might not interfere with the radio.
Old April 29th 10, 10:32 PM posted to rec.aviation.soaring
Darryl Ramm
I don't know what MEMS gyro sensor is in the TruTrak but may only be
10s of kHz or so. And with very low drive current so not much power
involved, and the oscillator electronics tends to be integrated onto
the sensor assembly so not much chance for harmonic leakage.
If the device is putting out RF, specially on the power supply leads I
am much more prone to think of a failed DC/DC (switchmode) converter
where the power involved is much more significant than the oscillator
circuit inside the MEMS sensor, and possibly chopped at a higher
frequency, and all conveniently close to the input wiring to leak back
if something has gone wrong.
Diagnosing the culprit here should be straight forward.
Darryl
Old April 29th 10, 02:02 PM posted to rec.aviation.soaring
JJ Sinclair
Some component is putting out RF, you can find which one by turning on
your radio with no squelch then one by one turn on each component,
GPS, vario, computer, recorder, etc. Each will add to the background
noise, look for the one that makes the greatest increased noise. I
recently found the new USB (stick) adapter for the SN-10 was pumping
out RF. I fixed the problem by moving it away from the radio antenna
lead.
Hope this helps,
JJ
Old April 29th 10, 09:10 PM posted to rec.aviation.soaring
Andy[_1_]
I think I'd first verify the problem can be reproduced using a hand
held TX. Then start disconnecting leads to/from the vario. Try
disconnecting each end of each lead in turn. Try powering the vario
from a local battery rather than ships power and wiring.
When you have pinned down the route the rf is entering the vario then
you are in a better position to work out how to fix it.
Large ferrite cores as close as possible to the vario may be a good
starting point. (They work best if the wire is looped rather than just
threaded) Changing wire routing many be another (make sure no vario
wiring is close the radio coax). If the vario outputs are typical
data and ground then screened twisted pair may be the next thing to
try. It may also help to ensure all leads feeding the vario are run
together as far as is possible. Having them spread out, or even
forming a large loop will increase the risk of RFI.
Perhaps the first question should be - did it always do this? If not
what was added or changed, or has something (perhaps rf filtering
components in the vario) failed.
Andy (GY)
Zaon MRX causing radio interference 2 Itsaplane[_2_] Soaring 17 August 2nd 09 02:51 PM
FM radio interference from planes rb Piloting 34 July 19th 06 05:53 PM
GPS / radio interference Cub Driver Piloting 2 October 31st 04 10:57 PM
radio / vario interference - HELP! Chris Davison Soaring 13 November 3rd 03 06:09 AM
Radio Interference Information Ross Richardson Piloting 0 October 17th 03 02:06 PM
