Wiring
Old July 3rd 10, 02:37 PM posted to rec.aviation.soaring
John[_27_]
Default Wiring
I'm considering installing a climb/cruise switch, gear warning, and
spoiler warning sensors (all driven by a C302). I've not done any
wiring on gliders before - is there a specific grade of wire that
should be used? And what gauge is typically used for this sort of
thing?
John
Old July 3rd 10, 10:35 PM posted to rec.aviation.soaring
Grider Pirate
Default Wiring
spoiler warning sensors (all driven by a C302). *I've not done any
should be used? *And what gauge is typically used for this sort of
thing?
John
http://www.aircraftspruce.com/menus/el/wire.html
22 ga. seems most common for signals, 18 ga. or larger for power
distribution.
Old July 4th 10, 12:17 AM posted to rec.aviation.soaring
Richard[_9_]
Default Wiring
thing?
John
John,
http://www.craggyaero.com/electrical.htm
Richard
www.craggyaero.com
Old July 4th 10, 04:01 AM posted to rec.aviation.soaring
ContestID67[_2_]
Default Wiring
Without a doubt you need to use Mil-Spec Tefzel wiring in all
aircraft. It isn't all the expensive and required as far as I
know.
The jacket is tough so that is isn't easily abraded causing
sparks
and fire. If there is a fire the jacket resists burning and
doesn't
emit toxic fumes.
For all of these low current applications that you mention,
anything
from 22-26 and smaller gauge will work - the smaller the better to
a
point). Look for multiconductor to save yourself some additional
wiring. Below are some sources. You don't need shielded in a
non-
motorized glider IMHO. No ignition system!
http://wingsandwheels.com/page5.htm smallest is 22gauge
http://www.aircraftspruce.com/catalo...es/wc2wire.php 5
conductor 26 gauge
http://www.aircraftspruce.com/menus/el/wire.html smallest 24
gauge
(I don't think that http://cumulus-soaring.com carries Tefzel wire
as
yet)
Lastly, as to gear/spoiler warning you need to make sure that you
are
not interfering with the regular operation of the glider with
switches/
wiring and need to be very careful if you are planning on drilling
any
holes. General, most gear warning systems that I see use
mechanical
micro-switches (http://cumulus-soaring.com/misc/switch-
lever-1.jpg).
These have to rub against something to be activated (where
exactly?)
which can lead to wear where you don't want it. I prefer magnetic
reed switches (http://cumulus-soaring.com/hamlin.htm) which don't
have
any wear points as they don't rub against anything. When a magnet
gets next to the reed, a "switch" is closed or opened (depending
on
how you have it wired). You tape or glue (I prefer non-permanent
solutions) the magnet to the airbrake and gear mechanism somewhere
(trial and error part) and glue the "switch" to an adjacent
surface.
Easy.
Full disclosu For standard airworthiness aircraft you need
someone
official to sign off on this mod. As I understand it, if you
didn't
build 50% of your experimental aircraft, I think that you also
have
to have have someone sign off. My $0.02. Stay safe.
- John DeRosa "67R"
Old July 4th 10, 09:59 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
Default Wiring
For what it's worth, the accident experience in the UK suggests that
much more expensive accidents, including some injuries, have happened
as a result of gear warnings going off and causing the pilot to start
pulling levers, and losing pitch control, at low level, rather than
the relatively minor damage of landing with the undercarriage up.
Somebody else thought of, and I adopted, a much simpler and cheaper
arrangement than electric audible warning. I have a sticky label which
I put on the vario face. If it is still there when I come off tow and
start soaring, I have forgotten to raise the undercarriage. I then put
it on the air brake/spoiler lever.
If it is still on the air brake/spoiler lever when I come into land, I
have forgotten to lower the undercarriage.
So far, whenever I have remembered to use it, it has worked.
Chris N
Old July 4th 10, 04:17 PM posted to rec.aviation.soaring
bildan
Default Wiring
Of course, this should also apply to retractable gear airplanes which
all have electronic gear warning systems. I think there is no such
accident record there.
If a pilot becomes so distracted by a gear warning system he crashes,
any other distraction would do the same. Clearly, the problem isn't
the gear warning, it's the pilot's reaction to it which suggests
extremely poor training.
Old July 4th 10, 06:13 PM posted to rec.aviation.soaring
Default Wiring
You don't need "good soldering skills", if you use crimp on
connectors, which are preferred over solder joints.
Consider a seperate power source (9 V battery) for your gear warning.
More on wiring he
http://www.matronics.com/aeroelectric/Downloads.html
Old July 5th 10, 04:07 AM posted to rec.aviation.soaring
Guy Byars[_2_]
Default Wiring
Gear warnings are not always 100% effective:
http://www.youtube.com/watch?v=-K4QHpVXtxI
Old July 4th 10, 01:35 PM posted to rec.aviation.soaring
Andy[_1_]
Default Wiring
aircraft.
Why don't you take your crusade to the manufacturers themselves. As
long as they build an certify gliders with PVC insulated wiring you
will have a hard time convincing end users that tefzel is required
*without a doubt*.
Andy
Old July 4th 10, 02:17 PM posted to rec.aviation.soaring
Warren
Default Wiring
You don't need to use mil-spec wire. More importantly, you do need
good soldering skills.. Most people who think they can solder really
don't know how. Get some help if you have never worked with small
guage wire.
Wiring in a KI 214 apachearmtguy General Aviation 1 November 10th 09 02:15 AM
wiring Jerry Wass Home Built 7 January 3rd 09 09:03 PM
Q about mic wiring ken ward Soaring 2 May 31st 05 10:33 PM
Wiring KX 175 TSO Tore B. General Aviation 0 May 6th 04 10:02 PM
Wiring KDR-510 Chad Lemmen Owning 3 September 16th 03 02:03 PM
