O200 reassembly
Old September 6th 10, 09:43 AM posted to rec.aviation.homebuilt
Philippe[_4_]
Default O200 reassembly
hello,
I will begin the engine final assembly.
I read I need to begin with the 3 dowel screws and the front
two 7/16 through studs and low rear3/8 stud.
I don't find the tight order after that.
I guess it is better to tight all the stud nuts on big machined
washer before the sealant cure and fit the cylinders next
day.
I own and read the overhaul manual. If I don't find any order, I
will begin with center bearing, rear bearing next and remaining
front bearing nuts. At the end, all the flange bolts.
Thanks for any help
http://www.youtube.com/v/k6AP4SbRHNo...s=1&rel=0
Philippe Vessaire Ò¿Ó¬
C85 and O200 piston Philippe[_4_] Home Built 2 August 11th 10 05:47 PM
O200 overhaul Philippe[_4_] Home Built 0 May 30th 10 08:38 PM
O200 cylinder Philippe Vessaire[_3_] Home Built 3 October 19th 08 11:21 AM
O200 engine Philippe Vessaire Home Built 7 August 17th 07 08:53 PM
O200 nose Philippe Home Built 0 July 22nd 05 08:09 PM
