I sorta hate to interrupt the conversations by asking a question about
actual weather, but here we are... Last fall, I posted a question on "where's the next thermal" that got helpful responses. Somewhere in this group, a pilot made the observation that on some days, the thermals vanish mid-afternoon -- and if this pause can be weathered, it's possible to stay up until sunset. This led me to think about my own northern-plains experiences. Often I've gotten low, or thought the day had died, in midafternoon (3-4 pm). One flight in particular, this summer -- http://www.onlinecontest.org/olc-2.0...Id=-1396180689 -- I had flown ENE, and after making the first turnpoint at about 2:45 pm, I couldn't find any lift at all. At about 600' (175m) agl, I gave up scratching and restarted my engine while aproaching a field. All the clouds as far as I could see had turned raggedy and shrinking. I assumed the day was for some reason done (upper-level dry front?). After I'd been despondently climbing with engine for a few minutes, I realized that all the bases look good again, shut down, and had an easy thermalling flight back home. I can recall other, similar times, usually with a 20-30 minute episode of scratching around down low, when I blamed myself, or the small upwind lake, or the unknowns. But this day and that prior post makes me wonder whether the boundary layer might not "shift gears" midafternoon more often than we realize. In this respect, I have (as others, I'm sure) that early in the day the thermal sources are single fields and the lift broken and narrow; late in the day, the thermal sources are savannas and the lift broad and smooth, whether or not strong. 1: Do you have any meterological knowledge or links to suggest regarding this? 2: Have you seen this phenomenon? Thanks, Dan Johnson |
On Nov 4, 2:26*pm, danlj wrote:
I sorta hate to interrupt the conversations by asking a question about actual weather, but here we are... Last fall, I posted a question on "where's the next thermal" that got helpful responses. Somewhere in this group, a pilot made the observation that on some days, the thermals vanish mid-afternoon -- and if this pause can be weathered, it's possible to stay up until sunset. This led me to think about my own northern-plains experiences. Often I've gotten low, or thought the day had died, in midafternoon (3-4 pm). One flight in particular, this summer --http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?flightId... -- I had flown ENE, and after making the first turnpoint at about 2:45 pm, I couldn't find any lift at all. At about 600' (175m) agl, I gave up scratching and restarted my engine while aproaching a field. All the clouds as far as I could see had turned raggedy and shrinking. I assumed the day was for some reason done (upper-level dry front?). After I'd been despondently climbing with engine for a few minutes, I realized that all the bases look good again, shut down, and had an easy thermalling flight back home. I can recall other, similar times, usually with a 20-30 minute episode of scratching around down low, when I blamed myself, or the small upwind lake, or the unknowns. But this day and that prior post makes me wonder whether the boundary layer might not "shift gears" midafternoon more often than we realize. In this respect, I have (as others, I'm sure) that early in the day the thermal sources are single fields and the lift broken and narrow; late in the day, the thermal sources are savannas and the lift broad and smooth, whether or not strong. 1: Do you have any meterological knowledge or links to suggest regarding this? 2: Have you seen this phenomenon? Thanks, Dan Johnson This can certainly happen when there's a wind change, which messes up the thermal formation. A while after the change, things get going again... I'm sure there are other explanations but this is a situation I've seen a few times. Hope that helps, Best Regards, Dave |
On Nov 4, 1:52*pm, Dave Nadler wrote:
On Nov 4, 2:26*pm, danlj wrote: I sorta hate to interrupt the conversations by asking a question about actual weather, but here we are... Last fall, I posted a question on "where's the next thermal" that got helpful responses. Somewhere in this group, a pilot made the observation that on some days, the thermals vanish mid-afternoon -- and if this pause can be weathered, it's possible to stay up until sunset. This led me to think about my own northern-plains experiences. Often I've gotten low, or thought the day had died, in midafternoon (3-4 pm). One flight in particular, this summer --http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?flightId... -- I had flown ENE, and after making the first turnpoint at about 2:45 pm, I couldn't find any lift at all. At about 600' (175m) agl, I gave up scratching and restarted my engine while aproaching a field. All the clouds as far as I could see had turned raggedy and shrinking. I assumed the day was for some reason done (upper-level dry front?). After I'd been despondently climbing with engine for a few minutes, I realized that all the bases look good again, shut down, and had an easy thermalling flight back home. I can recall other, similar times, usually with a 20-30 minute episode of scratching around down low, when I blamed myself, or the small upwind lake, or the unknowns. But this day and that prior post makes me wonder whether the boundary layer might not "shift gears" midafternoon more often than we realize. In this respect, I have (as others, I'm sure) that early in the day the thermal sources are single fields and the lift broken and narrow; late in the day, the thermal sources are savannas and the lift broad and smooth, whether or not strong. 1: Do you have any meterological knowledge or links to suggest regarding this? 2: Have you seen this phenomenon? Thanks, Dan Johnson This can certainly happen when there's a wind change, which messes up the thermal formation. A while after the change, things get going again... I'm sure there are other explanations but this is a situation I've seen a few times. Hope that helps, Best Regards, Dave- Hide quoted text - - Show quoted text - Here in Wisconsin, this "cycling" is fairly common. We see it a handful of times each season. Some days it can be pretty exagerated. Although when it happens, it doesn't typically happen just once a day. We can sometimes see cycles as frequent as a half hour to an hour. Here's my take on why this happens. The clouds build to the point where they create enough shadow to reduce the heating on the ground. Once the thermals weaken and the clouds dissipate, the ground gets more sun and begins heating again starting a new cycle. Not sure if this is the case the original poster is describing, but it appears to be what's going on around here. When we fly on these kind of days, we have to take advantage of the strong part of the cycle to make distance, then loiter around in a weak thermal or fly very conservatively until the weak part of the cycle ends. |
On Nov 4, 3:38*pm, Westbender wrote:
On Nov 4, 1:52*pm, Dave Nadler wrote: On Nov 4, 2:26*pm, danlj wrote: I sorta hate to interrupt the conversations by asking a question about actual weather, but here we are... Last fall, I posted a question on "where's the next thermal" that got helpful responses. Somewhere in this group, a pilot made the observation that on some days, the thermals vanish mid-afternoon -- and if this pause can be weathered, it's possible to stay up until sunset. This led me to think about my own northern-plains experiences. Often I've gotten low, or thought the day had died, in midafternoon (3-4 pm). One flight in particular, this summer --http://www.onlinecontest..org/olc-2.0/gliding/flightinfo.html?flightId... -- I had flown ENE, and after making the first turnpoint at about 2:45 pm, I couldn't find any lift at all. At about 600' (175m) agl, I gave up scratching and restarted my engine while aproaching a field. All the clouds as far as I could see had turned raggedy and shrinking. I assumed the day was for some reason done (upper-level dry front?). After I'd been despondently climbing with engine for a few minutes, I realized that all the bases look good again, shut down, and had an easy thermalling flight back home. I can recall other, similar times, usually with a 20-30 minute episode of scratching around down low, when I blamed myself, or the small upwind lake, or the unknowns. But this day and that prior post makes me wonder whether the boundary layer might not "shift gears" midafternoon more often than we realize. In this respect, I have (as others, I'm sure) that early in the day the thermal sources are single fields and the lift broken and narrow; late in the day, the thermal sources are savannas and the lift broad and smooth, whether or not strong. 1: Do you have any meterological knowledge or links to suggest regarding this? 2: Have you seen this phenomenon? Thanks, Dan Johnson This can certainly happen when there's a wind change, which messes up the thermal formation. A while after the change, things get going again... I'm sure there are other explanations but this is a situation I've seen a few times. Hope that helps, Best Regards, Dave- Hide quoted text - - Show quoted text - Here in Wisconsin, this "cycling" is fairly common. We see it a handful of times each season. Some days it can be pretty exagerated. Although when it happens, it doesn't typically happen just once a day. We can sometimes see cycles as frequent as a half hour to an hour. Here's my take on why this happens. The clouds build to the point where they create enough shadow to reduce the heating on the ground. Once the thermals weaken and the clouds dissipate, the ground gets more sun and begins heating again starting a new cycle. Not sure if this is the case the original poster is describing, but it appears to be what's going on around here. When we fly on these kind of days, we have to take advantage of the strong part of the cycle to make distance, then loiter around in a weak thermal or fly very conservatively until the weak part of the cycle ends.- Hide quoted text - - Show quoted text - You'll often hear racing guys talking about being "in-synch with the day" or "out-of-synch with the day" (the latter condition usually being described with expletives preceeding). When you're in-synch with the day, you seem to hit a thermal just when you'd be starting to dial back from go-fast mode to search-mode. I'm thinking of a 60 mile leg at Mifflin this year where there were 6kt climbs spaced at 15 mile intervals with 6,000-7,000 foot bases. Climb at 6 kts, blast off 'till you're getting down around 4,000, hit 6kts, repeat... UNTIL it stopped working. Suddenly, the two good climbs were right next to each other, followed by 20 miles of nothin, nada, nichts. Different airmass? Different terrain? Something else? Certainly in mountainous or hilly areas, there are mountain/valley effects which can wash out large areas. Over flat lands, we defininitely see the overdevelop/cool-off/regenerate cycling. In addition, warmer air aloft can advect or an excess of moisture at the LCL can lead to larger scale spreadout. Still other times wave can set up with the right wind conditions and enhance some areas which suppressing others. All of these can turn a great day into a difficult day in short order. P3 |
On Nov 4, 3:15*pm, Papa3 wrote:
On Nov 4, 3:38*pm, Westbender wrote: On Nov 4, 1:52*pm, Dave Nadler wrote: On Nov 4, 2:26*pm, danlj wrote: I sorta hate to interrupt the conversations by asking a question about actual weather, but here we are... Last fall, I posted a question on "where's the next thermal" that got helpful responses. Somewhere in this group, a pilot made the observation that on some days, the thermals vanish mid-afternoon -- and if this pause can be weathered, it's possible to stay up until sunset. This led me to think about my own northern-plains experiences. Often I've gotten low, or thought the day had died, in midafternoon (3-4 pm). One flight in particular, this summer --http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?flightId... -- I had flown ENE, and after making the first turnpoint at about 2:45 pm, I couldn't find any lift at all. At about 600' (175m) agl, I gave up scratching and restarted my engine while aproaching a field. All the clouds as far as I could see had turned raggedy and shrinking. I assumed the day was for some reason done (upper-level dry front?). After I'd been despondently climbing with engine for a few minutes, I realized that all the bases look good again, shut down, and had an easy thermalling flight back home. I can recall other, similar times, usually with a 20-30 minute episode of scratching around down low, when I blamed myself, or the small upwind lake, or the unknowns. But this day and that prior post makes me wonder whether the boundary layer might not "shift gears" midafternoon more often than we realize. In this respect, I have (as others, I'm sure) that early in the day the thermal sources are single fields and the lift broken and narrow; late in the day, the thermal sources are savannas and the lift broad and smooth, whether or not strong. 1: Do you have any meterological knowledge or links to suggest regarding this? 2: Have you seen this phenomenon? Thanks, Dan Johnson I got shot down by a solar eclipse in Colorado; Knew it was going to happen, didn't put one plus one together with respect to the effect on solar heating. Predictable and rare. |
happen, didn't put one plus one together with respect to the effect on solar heating. *Predictable and rare. that brings up an interesting question, are position lights required to fly during a solar eclipse? |
It only takes one... | Kyle Boatright | Piloting | 45 | May 5th 07 06:30 AM |
Do you have what it takes? | Flyingmonk | Piloting | 6 | February 4th 06 05:22 PM |
What Kit takes a TCM IO-240 | Bob | Home Built | 8 | December 22nd 04 02:36 AM |
What Kit takes a TCM IO-240 | Bob | Home Built | 0 | December 18th 04 05:38 PM |
DG takes over LS | Greg Arnold | Soaring | 3 | March 3rd 04 08:32 AM |
