New Prop on my Mooney Ovation
Old July 7th 03, 06:01 AM
Charles Talleyrand
Default New Prop on my Mooney Ovation
I have read that the main difference between the Ovation and the Ovation II is the better prop on the second airplane. Can one
install the new prop on the old model. It's the same airplane and the same engine between both the Ovation and Ovation II, so the
only worries are legal ones.
Finally, I have read that the Ovation engine is flat-rated by limiting the RPM to 2,500. Can one change the pitch on the prop to
get higher performance and how would one make this paperwork work?
-Thanks
P.S. Nope, I don't actually own a Mooney. I'm just dreaming.
Old July 7th 03, 10:30 PM
Dan Luke
RPM to 2,500.
Can one change the pitch on the prop to get higher performance
It's a constant speed prop; it changes its own pitch. Conceivably, one might
adjust the prop governor control to allow higher rpm.
Dan
C172RG at BFM
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
