Komet Trailer Suspension Parts
Old December 12th 10, 03:47 AM posted to rec.aviation.soaring
Randy[_2_]
Default Komet Trailer Suspension Parts
A friend of mine is in need of some replacement parts for his
1984 Komet Trailer. During the drive home in a dark and heavy
rain storm in central Oklahoma, he had a tire separation on the
top side of the tire that caused damaged to fiberglass top, broke
the locks on both ends of the trailer.
The ramp and jack were lost on the highway. The bulge in
the tire wore a hole through the top of the fender.
The latest thing to fail on this trailer and now needs to be replaced
is the suspension.
Does anyone know where in the US that we can find replacement
parts for the suspension? Does anyone know of a damaged trailer
that someone might be willing to part out?
The glider survived with a few excessive rub marks in the gel
coat from the trailer, otherwise no damage has been located.
The trailers tires were a little over five years old and the trailer
is stored in a hangar when not in use.
Check your tires. 4 to 5 years seems to be the time limit on trailer
tires whether you have a lot of miles on them or just a few.
Thanks for your time!
Randy
Tulsa, OK
http://talihinasoaring.com/
Old December 13th 10, 12:47 AM posted to rec.aviation.soaring
Mike the Strike
is the suspension.
Randy
Tulsa, OK
I had a Komet trailer that was damaged in an accident some years ago
(actually a road rage incident in which the trailer was deliberately
rammed by an angry driver!). We switched out a few components for US
standard ones, including the axle, suspension and wheels. I also had
a ramp with heavy-duty scissor jack fabricated quite inexpensively by
a local welding shop. You might check out both local and imported
options.
Old December 13th 10, 04:31 PM posted to rec.aviation.soaring
Morgan[_2_]
Randy,
Take a look at the following video to an enhanced option for a ramp/
jack replacement.
http://www.youtube.com/watch?v=0abKXYtBlu8
A little scouring of the internet or your local trailer manufacturers
will probably yield something you can modify to use as an axle.
Old December 13th 10, 04:45 PM posted to rec.aviation.soaring
sisu1a
Get rid of the Komet gear and put on a Torflex axle. If he really
likes the plane, get the rest of the electric brake setup that goes on
it too (all Torflex axles come with the brake flange on it), but this
is not necessary. This axle is like $160 and includes the
(independent) suspension which makes it drive reeeaal nice and they're
made to order, so of course it will fit perfect. I loved my Torflex
axle (previous trailer...)
-Paul
Old December 15th 10, 04:04 AM posted to rec.aviation.soaring
Randy[_2_]
Thanks for all the information. The Jack/Ramp idea will be used
by another club member and a new Torflex Axle will be ordered
this week. A Torflex distributor was located just 6 miles from home.
http://www.dexteraxle.com/torflex_axles
Randy
Trailer Suspension Tony Condon[_2_] Soaring 9 June 12th 09 03:50 PM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
Komet Trailer Gas Springs P. Corbett Soaring 4 March 11th 07 11:30 PM
Komet Trailer Rims Tim Hanke Soaring 6 February 28th 06 04:56 PM
