Using Balsa wood
Old December 6th 03, 09:11 PM
Lou Parker
Default Using Balsa wood
In many area's on my wood structure it calls for a filler. Usually
spruce, but for no other reason but to fill a gap. These are not
structural in the least, only to fill (i.e. on top of the spar a 1/4"
strip of wood to keep the plywood skin from saging in between the wing
ribs). Has anyone used Balsa wood to accomplish this to save on
weight. There seems to be alot of little areas like this in my plans.
Lou
Old December 6th 03, 10:17 PM
Rich S.
"Lou Parker" wrote in message
om...
The only place I used balsa was on the fairing to shape the back of the nav
light housings on the wing tips. While every ounce counts, is there really
that much cubic volume where the difference between spruce and balsa would
add up to a significant amount (on the cheeseburger scale)?
Rich S.
Old December 6th 03, 10:38 PM
sean trost
Hi Lou,
I am currently in the process of rebuilding a Jurca Mj-5 that has balsa
as a filler in many areas such as the firewall, some areas in the
fuselage and the wingtips and elevator tips are also balsa. The
condition of the balsa after 15 years is just abysmal. I would go with
polyeurathane foam or spruce.
all the best
Sean Trost
Lou
Old December 7th 03, 12:54 AM
Vaughn
om...
weight.
Some early fiberglass gliders use balsa as a filling in the wings and
mildew is an issue. I think that there is a procedure to chemically treat
the balsa inside the wing to kill it.
Vaughn
Old December 7th 03, 01:39 AM
Nolaminar
Oldest fiberglass aircraft date from 1957. German made sailplanes and they used
balsa core and have had very few problems.
A fw of thsesl of these same older designs are still flying and have had
minimal problems if properly cared for and sealed properly...just as in any
wood aircraft.
GA
Old December 7th 03, 01:58 AM
frank
Wouldn't the spruce fillers act as a lamination on the spar caps?
Old December 7th 03, 10:23 PM
Martin Morgan
Yes but only where they are attached. Since "between the ribs" was
mentioned I'd say there was no benefit.
However, if the plywood skin is handling any loads eg. torque loads,
then the balsa may be a problem!!
Balsa is used in the Knight Twister (cantilever biplane). It has a
plywood torque box (probably a better term here), and uses the balsa to
fill in the leading edge and tips.
So yes, balsa (or foam) can be used in some places for lighter
structures. But I'd be wary of using it where it attaches two stronger
materials..
Regards
Martin Morgan
Old December 8th 03, 01:00 PM
Lou Parker
Martin Morgan wrote in message . com.au...
materials..
Regards
Yes, part of it calls for in between the ribs on the spars for a
filler. That is the front and back of the main spar and across the
rear spar as a filler. Also on the trailing edge of the flaps,
ailerons, and elevator control, (lets see if I can explain this) where
the trailing edge meets the structural pieces. On top of these areas
plywood will be glued, and then Dacron. At the part where the trailing
edge meets the structural pieces, it calls for a 45 deg. filler to
help round out the plywood. Now, have I confused everyone, or just
a few?
Lou
Martin Morgan
Old December 8th 03, 05:08 PM
Orval Fairbairn
. com.au...
materials..
Regards
a few?
Lou
Martin Morgan
Years ago, I had a friend who built a Thorp T-18 with painted balsa tail
tips. It was tied down outside; one day he pulled a fin tip off for
maintenance and found it sopping wet! Be very wary of using balsa if it
gets exposed to moisture.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
Wood questions - Public Lumber Company, determining species at the lumberyard Corrie Home Built 17 September 17th 03 06:51 PM
Direction of warping wood? BllFs6 Home Built 2 September 1st 03 10:52 AM
