Vertical-card vs whiskey compass
Old August 17th 03, 05:40 PM
Henry Bibb
Default Vertical-card vs whiskey compass
The compass in my plane decided to spontaneously emit fluid all
over the glareshield the other day, so I'm looking at options for
replacement.
I've Googled for opinions on the vertical-card vs whiskey issue,
and came away no wiser - anybody care to comment from fairly
recent experience?
This is for a VFR-only airplane without a DG.
Thanks in advance,
Henry Bibb
Old August 17th 03, 10:15 PM
Ross Oliver
replacement.
recent experience?
Avionics West has a fairly detailed writeup of their experience
with a vertical card compass:
http://www.avionicswest.com/articles.htm
According to this article, a vertical card compass is extremely
delicate, and prone to being knocked out of service by any magnatized
object coming into its proximity, even briefly.
My compass isn't even broken, and I'm thinking of replacing
it with this:
http://www.vargaair.com/navigator.htm
It would be worth the $200 just to be able to READ the darn thing,
especially at night.
Ross Oliver
Old August 18th 03, 12:14 AM
Mike Granby
magnatized object coming into its proximity, even briefly.
That isn't my experience.
I love my vertical card compass, and wouldn't switch back for anything.
Mike Granby, PP-ASEL,IA
Warrior N44578
http://www.mikeg.net/plane
Old August 18th 03, 01:55 AM
Doug Vetter
replacement.
recent experience?
Henry,
I just replaced our Precision Vertical Card compass with a SIRS unit so
this is still fresh in my mind.
You have basically three options:
1) Standard Airpath "whiskey" compass (About $175)
2) Vertical Card (Precision about $225)
3) SIRS Navigator (http://www.sirsproducts.com/ ($215)
I installed a SIRS because our 400+hour vertical card had developed
errors that had become uncorrectable, it tended to stick occasionally in
turns, and my avionics shop refused to install and warranty a new
vertical card due to MANY customer complaints and warranty claims.
As I see it, the chief benefits of the SIRS unit over the Airpath a
1) The rotating mass is smaller, and they use a lens to make the card
appear as large as required by the TSO. The smaller mass reduces the
acceleration/turning effects. I've seen this first hand.
2) Clear silicone fluid Vs. Kerosene. I don't know if the silicone
fluid will discolor over the years, or whether it really damps the card
oscillations, but at least if it leaks I won't have a flammable liquid
running down into my radio stack.
3) The lighting is LED. LEDs draw less power for the light they produce
and simply won't burn out in the operational lifetime of the compass (if
not the airplane). One less thing to worry about.
4) And, for what it's worth, SIRS Navigation produces high-grade
compasses for many industries, and a different model of this compass is
used as the standby in the Concorde.
Hope this helps,
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Old August 18th 03, 02:00 PM
Joe Young
Henry
I replaced my whiskey with a vertical card compass about 6 months ago over
the concerns of my A&P. It is fantastic, and the A& P's concerns were
unfounded. It is much easier to read, more stable and the lighting is great
for night flight...
Joe
"Henry Bibb" wrote in message
replacement.
recent experience?
Thanks in advance,
Henry Bibb
Aircraft Spruce: Abused Customers and Fourteen More Angry Comments -- More to Come jls Home Built 2 February 6th 05 09:32 AM
GPS approaches with VNAV vertical guidance Doug Instrument Flight Rules 18 November 2nd 04 11:36 PM
Reading the whiskey compass Ben Jackson Instrument Flight Rules 20 February 28th 04 09:09 AM
"Whiskey" for compass? dale Home Built 10 December 18th 03 12:16 AM
Vertical Card Compass compatible with "V" brace? Jeff P Owning 1 July 11th 03 04:46 AM
