I'm trying to build an inexpensive yet effective rudder lock for an
assembled GROB 103 or TWIN ASTIR. Have tried two or three approaches but not happy with any thus far. Needs to be rugged, lightweight, and user friendly (think club environment). Any ideas? Mike |
Consider fabricating an inside-the-cockpit, front seat only -- lock
or damper. Something you would see getting in. Rear cockpit control locks WILL be overlooked. Bungee cords work well to dampen the movement and might fold up nicely. Decorate with red ribbons. Add control lock item(s) to pre-flight and post-flight checklists. (Google "Checklist Boeing B-17" for a reason to create / use pre- flight checklists.) |
On Apr 18, 3:07*pm, Burt Compton - Marfa wrote:
Consider fabricating an inside-the-cockpit, front seat only -- *lock or damper. Something you would see getting in. Rear cockpit control locks WILL be overlooked. Bungee cords work well to dampen the movement and might fold up nicely. Decorate with red ribbons. Add control lock item(s) to pre-flight and post-flight checklists. (Google "Checklist Boeing B-17" for a reason to create / use pre- flight checklists.) If memory serves me, I believe I hooked a bungee from one rear rudder pedal to fuselage structure so that the bungee held the rudder against one stop. Won't work from the front cockpit because those pedals are cable driven, but the rear is hooked directly to a pushrod. For sure, attach a long red streamer that hangs over the front seat. JJ |
On Apr 18, 2:11*pm, wrote:
I'm trying to build an inexpensive yet effective rudder lock for an assembled GROB 103 or TWIN ASTIR. Have tried two or three approaches but not happy with any thus far. Needs to be rugged, lightweight, and user friendly (think club environment). Any ideas? Mike Heavy gauge PVC pipe with elbows and PVC glue and covered with water pipe insulator. Tie two pipes together with a bit of rope at the back through two holes. $20? |
On Apr 18, 3:26*pm, "Matt Herron Jr." wrote:
Heavy gauge PVC pipe with elbows and PVC glue and covered with water pipe insulator. *Tie two pipes together with a bit of rope at the back through two holes. *$20? That would be my preference. It's light and cheap, and is pretty sure to do the job at hand. Remember that you're not trying to completely immobilize the rudder, you're just trying to prevent it from hammering against its stops. Thanks, Bob K. |
On Apr 18, 6:32*pm, Bob Kuykendall wrote:
On Apr 18, 3:26*pm, "Matt Herron Jr." wrote: Heavy gauge PVC pipe with elbows and PVC glue and covered with water pipe insulator. *Tie two pipes together with a bit of rope at the back through two holes. *$20? That would be my preference. It's light and cheap, and is pretty sure to do the job at hand. Remember that you're not trying to completely immobilize the rudder, you're just trying to prevent it from hammering against its stops. Thanks, Bob K. It's exactly what we use on our G103. Only mod is that we use a hitch pin at the trailing edge rather than rope. |
| Thread Tools | |
| Display Modes | |
| Thanks for your input on videos | [email protected] | Soaring | 1 | February 18th 11 10:59 AM |
| M-Nav Gps input ? | Mark Courtney | Piloting | 0 | January 18th 11 07:25 PM |
| FAA ADS-B Out NPRM needs your input | Ron Lee[_2_] | Piloting | 24 | November 27th 07 05:06 AM |
| GTX 327 serial input? | weebee | Owning | 1 | December 19th 05 02:04 AM |
| Aux. Audio Input | Eugene Wendland | Home Built | 1 | April 5th 04 05:16 AM |
