Back-up IGC flight recorder
Old July 29th 11, 07:26 PM posted to rec.aviation.soaring
Vsoars
Default Back-up IGC flight recorder
I want to buy a back-up flight recorder. 63 invalid fixes on a long
flight has convinced me that my Volkslogger won't always record the
flight with the required accuracy. (I had the battery replaced last
year but now I am having problems on about 1 out of 4 flights. The
pattern of invalid fixes is- 4, 2, 30, 0,63, 23,21,49, 8, 10)
Old July 29th 11, 07:39 PM posted to rec.aviation.soaring
Darryl Ramm
Sorry maybe I'm missing the obvious but I'm not following that you mean
by pattern and what the numbers mean. I am not sure it's going to help
but if you want people to try to see something in that could you provide
a link to the IGC files on OLC or somewhere else.
Does the antenna have a good sky view? Have you tried a different
external antenna (if it is using one)?
I'm not sure if you need an full IGC flight recorder or whether a
PDA/PNA with separate GPS would be enough for your needs. But first
choice on my list now for a stand-alone IGC recorder would be an LX Nav
Nano. Actually the Volkslogger would be the backup...to the nano.
Darryl
Old July 29th 11, 08:03 PM posted to rec.aviation.soaring
Paul Remde
Hi,
The LXNAV Nano has been the popular unit lately. Customers seem to like
that it is very small, has a built-in battery and antenna, and is very
simple to use. I has also proven to be very reliable.
I also sell the EW microRecorder, but I'd use the Nano myself - unless you
have soaring friends using the EW - so you can help each other if necessary.
But the EW is also very easy to use.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Vsoars" wrote in message
Old August 1st 11, 01:32 PM posted to rec.aviation.soaring
Nick Hill[_3_]
On 29/07/2011 20:03, Paul Remde wrote:
Hi,
you have soaring friends using the EW - so you can help each other if
necessary. But the EW is also very easy to use.
Best Regards,
One question about the Nano which I wasn't happy about - I may be wrong
but it seems it does not have any internal memory like other loggers.
The only place the trace gets stored is on the SD card. Other loggers
with SD cards keep the trace in internal memory and just use the SD card
for transfers.
The Nano manual specifically says with a big red warning triangle next
to it that although it has a removable SD card that removing the card is
not recommened and also recommends always copying flights off the Nano
in case of SD card failure.
I believe the new Colibri II does have internal memory and just uses the
SD card for transfering traces. May be a better bet once it is fully IGC
approved?
Nick Hill
Old August 1st 11, 05:23 PM posted to rec.aviation.soaring
Paul Remde
Hi Nick,
I don't see it is a problem that the Nano saves flight logs only on the
microSD card. MicroSD cards are just as reliable as internal Flash memory.
I have sold quite a few Nanos and so far the feedback has been very
positive. It has proven very reliable.
I fly with a Nano and I trust it.
Best Regards,
Paul Remde
"Nick Hill" wrote in message
Hi,
Best Regards,
but it seems it does not have any internal memory like other loggers. The
only place the trace gets stored is on the SD card. Other loggers with SD
cards keep the trace in internal memory and just use the SD card for
transfers.
The Nano manual specifically says with a big red warning triangle next to
it that although it has a removable SD card that removing the card is not
recommened and also recommends always copying flights off the Nano in case
of SD card failure.
approved?
Nick Hill
Old August 1st 11, 11:01 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
That makes a lot of sense. Any analysis of the lifetime of SD card
component lifetimes if its used for a relatively slow logging application
(and recording 36 bytes once a second is pretty slow) shows that the
contacts will wear out before the flash memory if its used to transfer
logs from recorder to computer.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 4th 11, 03:11 AM posted to rec.aviation.soaring
kammeyer
flight has convinced me *that my Volkslogger won't always record the
flight with the required accuracy. *(I had the battery replaced last
If you have an iPhone, check out the GlidePath app. It's $10, and the
logs are approved for OLC.
Old August 5th 11, 07:14 PM posted to rec.aviation.soaring
kammeyer
You might consider the iPhone app GlidePath. If you already have an
iPhone, it is only $10, and it's approved for OLC flights, and is very
easy to email logs or submit them to OLC straight from the phone.
-Dave
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 08:31 PM
In flight recorder Lou Piloting 23 March 24th 07 12:45 AM
EW B-Model flight recorder BDS Soaring 12 August 19th 06 04:39 PM
Back up Flight Recorder for US contests Udo Rumpf Soaring 13 April 6th 06 03:27 PM
who does Flight Recorder calibration... ken ward Soaring 4 March 5th 04 02:28 AM
