LS-8 outer ballast tank filler thingie
Old September 3rd 11, 02:05 AM posted to rec.aviation.soaring
Tuno
Default LS-8 outer ballast tank filler thingie
The outer ballast tanks use a fitting what I don't have. Is there an
off the shelf workaround?
tuN7o
Old September 3rd 11, 02:38 AM posted to rec.aviation.soaring
Papa3
For the outers, yes. I don't have mine in front of me, but it's just a rigid plastic fitting of thick walled pipe. It has a slight taper iirc, but it is a friction fit. A length of PVC with the right od would work.
Old September 3rd 11, 04:40 PM posted to rec.aviation.soaring
Peter Wyld[_2_]
tuN7o
probably not, it's a tapered tube - the taper end is rammed into the hole
in the wing and suitable supply of water applied to the other end.
Find someone who has one and turn down a suitable thick walled tube to
match the taper.
Old September 3rd 11, 05:15 PM posted to rec.aviation.soaring
vaughn[_3_]
"Peter Wyld" wrote in message
. com...
match the taper.
Schedule 80 PVC pipe or electrical conduit of an appropriate diameter would
likely be a good material to make that from. It may not be a retail item, but
is redily available at a wholesale plumbing or electrical supply.
Alternatively, you might get lucky enough that the bell end cut from a length of
ordinary PVC pipe would serve.
Vaughn
Old September 5th 11, 08:27 AM posted to rec.aviation.soaring
bumper[_4_]
tuN7o
If you are around Minden I can probably make you one if I have either
the plane or fitting to look at. . . Or a diagram.
Bumper
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg [email protected] Aviation Photos 0 April 12th 07 01:33 AM
A different way to add filler (OA) mhorowit Home Built 0 September 14th 05 12:51 PM
ASW-27B ballast tank ventilation Andy Blackburn Soaring 3 October 24th 04 05:31 PM
Oil filler cap assy Test Home Built 2 January 23rd 04 01:38 PM
GTAW / TIG filler material recommendations Jari Kaija Home Built 8 July 3rd 03 06:01 AM
