Ceconite Wings Question
Old October 13th 04, 02:45 PM
Captain Wubba
Default Ceconite Wings Question
Hello. I'm considering purchasing a plane that has Ceconite wings.
They were recovered last year professionally, and according to an A&P
I asked to have a quick look, were done well and correctly, and have a
UV protectant. My question is the following: I don't have access to a
hanger. This plane would be exposed to the elements in the Midwest.
How long could I expect to fly this plane before the Ceconite would
need replacement? Is there an average 'lifespan' for this type of wing
covering if exposed to the elements?
Cap
Old October 14th 04, 01:51 AM
dave
My citabria was covered ten years ago with ceconite. The fabric is
perfect. The white paint is okay, the red has faded. It's now
hangered so I expect to get a lot more life out of it. Most people
I've spoke to prior to buying my plane said twenty years for a well done
fabric job that's taken care of. I've seen nearly new american
champion citabrias with cracked paint. A friend has a piper colt that
was covered with ceconite 25 years ago but always hangered. It's like
new.
You really have to get it checked by an A&P that works on fabric airplanes.
Dave
68 7ECA
Cap
Old October 14th 04, 02:21 AM
john smith
One theory is to not go more than ten years without recovering.
The theory being that after that much time exposed to the elements, you
would want to strip everything off to thoroughly inspect the airframe
for corrosion.
was covered with ceconite 25 years ago but always hangered. It's like new.
Dave
68 7ECA
Cap
Old October 14th 04, 03:13 AM
Kyle Boatright
"john smith" wrote in message
would want to strip everything off to thoroughly inspect the airframe for
corrosion.
The 10 year replacement theory is a great "perfect world" idea, but most
folks who are not named Buffet, Gates, Kennedy, etc. simply can't afford the
cost. Cover jobs are expensive. Real expensive. As in 4 years of college
tuition expensive, or downpayment on a small house expensive. Since the
sky isn't raining old rag wings, the 15-20 year re-cover cycle appears to be
adequate...
KB
Old October 14th 04, 01:02 PM
dave
I've heard that too but more like twenty years. If I needed to inspect
every little nook and crany of a fabric covered airplane every ten years
then why not a metal covered one?
for corrosion.
done fabric job that's taken care of. I've seen nearly new american
that was covered with ceconite 25 years ago but always hangered. It's
like new.
airplanes.
Dave
68 7ECA
Cap
Old October 14th 04, 04:54 PM
Michael
adequate.
Well, yes - but most old rag wings are hangared. I would have no
problem with a 20 year cycle for a hangared bird, but if it sits
outside for 10 years it probably needs recover.
Michael
Old October 14th 04, 07:54 PM
dave
"Kyle Boatright" wrote in message ...
corrosion.
adequate...
KB
There is no life limit on the new fabric material. UV is its only
weakness.
If the dope or paint has been put on properly, it will last as long as
the coatings last.
The coatings can get re-vitalized from time to time to keep them
plyable.
There is no reason why fabric can't last 20,30-40+ years if you don't
let the sun get to the fabric.
Like any airplane, the structure needs to be inspected whether it has
fabric or aluminum for covering.
Dave
Old October 14th 04, 09:34 PM
Montblack
("dave" wrote)
I was thinking that too - I'm whimsically looking at a 1946 Ercoupe, which is
going up
for auction this Saturday (16th). There's a beaten up Cessna 140 there also.
Pole barn projects that are soon to be someone else's problem ... I mean
project. Both are planes that will need much time and much money thrown their
way before they get in the air again.
What Kyle was saying about costs - What's a guess on the material cost (only)
for redoing a fabric covered airplane? How much of that college tuition level
price tag is material vs. labor?
Montblack
Old October 14th 04, 09:39 PM
Rick Macklem
john smith wrote in message .. .
for corrosion.
Dave
68 7ECA
I'm far from an expert on this, but I'll add a couple of things I've
heard, plus second what Dave said w.r.t. checking with an A&P that
does fabric work.
Ceconite uses non-tautening Butrate dope (not quite the same stuff
that is
used with cotton). Over time the plasticizer will leach out, resulting
in the
dope getting brittle and starting to crack. This can be remedied by
using a
"dope rejuvenator", if done soon enough. The only thing that damages
the fabric,
(short of hail or fire) is UV light. The silver dope protects it, but
cracks in
the dope can let the UV through.
Most fabric covered aircraft were designed when Cotton was the best
covering
available, and it lasted 10 years, at most. As such, the engineers
assumed the
underlying structure would be examined/repaired at least every 10
years. Some
aircraft now have a lot more inspection holes in the wing fabric than
they
would have had when they left the factory, to try and inspect the
internal
structure. Whether the internal structure is wood or metal is also a
consideration. (Inspecting wood with a flashlight and mirror on a
stick is
a specialized skill that not all A&Ps will have.)
Just what I've been told, rick
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 04:21 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Crooked or Wavy Trailing Edges of Wings and Control Surfaces Larry Smith Home Built 3 October 24th 03 02:31 AM
