Does anyone in the group use a 12v auxiliary heater or heated blanket for
added cabin or passenger heat? I've seen that they come in 150watt/12.5 amp and 300watt/ 30amp versions. We'd have to figure out the current load on our alternators but I'm wondering if we should even consider such an option for the rear seat passengers in our Aztec. I've seen this quesion asked before but it's been several years. Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/2004 |
What about portable heated seat cushions?? 12v/60watt/5amp 100-120 degrees
surface temp "Jim Burns" wrote in message ... Does anyone in the group use a 12v auxiliary heater or heated blanket for added cabin or passenger heat? I've seen that they come in 150watt/12.5 amp and 300watt/ 30amp versions. We'd have to figure out the current load on our alternators but I'm wondering if we should even consider such an option for the rear seat passengers in our Aztec. I've seen this quesion asked before but it's been several years. Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/2004 --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/2004 |
Back in WW2 they used to have heated flight suits for the crews
of military aircraft. I imagine that they were particularly useful in the high flying bombers with huge open gun ports on the sides. I had a pair of the slippers at one time, and found that they really did work. I used a variable DC supply to power them. Originally they ran on aircraft power (28V) through a rheostat. I never tried them in an airplane, but something similar may be what you need. I have seen some battery powered socks in outdoor supply catalogs. Another approach might be chemical heat pads. I happened to look at some in the hardware store the other day. You activate them by simply opening the package and exposing the pad to the air. Finding out if they will do the job will be cheap - they only cost a dollar or so. David Johnson |
On 18-Oct-04 20:40 zatatime wrote:
On 18 Oct 2004 20:05:15 -0700, (David Johnson) wrote: [snip] For some reason if your feet are warm your whole body feels a bit warmer. That's the theory I used when I wired in some Gerbing's electrically heated socks for my Long-EZ. They're economical (both cost-wise at $60 and energy-drain wise at 2A). I picked up a set in a Boise (Idaho) motorcycle shop but they're available on the web too. See http://www.gerbing.com/pages/clothing/socks.html Along with thermal underwear, they fill 90% of my heat requirements for wintertime flying at medium altitudes (FL010 to FL180) but my right hand still gets too cold for comfort. I think the stick's control grip is "sucking the heat" out of my hand so I'm looking at a Rube Goldbergesque scheme to put a small power resistor into the stick. -- Joe (Remove "NOSPAM" to reply via Email) Long-EZ 821RP Clarkston, WA |
heated socks for my Long-EZ. Hmm. This is something I'd not considered before, never having seriously considered a homebuilt plane. Do Long-EZs not have *any* heat? Does having the engine behind you preclude using hot air off the exhaust for cabin heat? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Joe Dubner wrote: I think the stick's control grip is "sucking the heat" out of my hand so I'm looking at a Rube Goldbergesque scheme to put a small power resistor into the stick. I bought a pair of deerskin gloves. They work very well at keeping my hands warm without being bulky. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Joe Dubner writes:
I think the stick's control grip is "sucking the heat" out of my hand so I'm looking at a Rube Goldbergesque scheme to put a small power resistor into the stick. or... http://www.hotgrips.com/styles.html --kyler |
In article , zatatime
writes: These things work great, just make sure they're on the outside of your socks. I used 'em a bunch flying Cubs in the winter. For some reason if your feet are warm your whole body feels a bit warmer. Boy Scouts say, "if your feet are cold, put on a hat." Much of your heat loss is via the head, so don't forget the hat in winter. Chuck |
I used a heated seat cushion, chemical packs (in lots of places)
and a little 12VDC car (air) heater when I was going between California and Indiana a couple winters ago without heat. I still froze. I recommend lots of insulative clothing and heating devices under that. (Try the heaters designed for motorcycle riders.) --kyler |
| Thread Tools | |
| Display Modes | |
| Any metallurgist's on the group, I want to heat treat aluminum? | [email protected] | Home Built | 3 | December 11th 04 12:50 PM |
| Carb heat specs? | Rich S. | Home Built | 2 | November 13th 04 05:39 PM |
| Painting and air cooled motor? | CitizenX | Home Built | 5 | June 30th 04 01:47 PM |
| Inside the Cowling Fire / Heat Detector? | George Sconyers | Owning | 5 | May 30th 04 08:04 PM |
| pitot heat question | K. Ari Krupnikov | Instrument Flight Rules | 7 | December 11th 03 02:51 AM |
