Canard nose pading
Old January 8th 04, 10:08 PM
Paul Lee
Default Canard nose pading
All you EZ/Cozy builders what do you put under the nose to protect
the fuselage when it is down? Extra thick paint?
Paul Lee, SQ2000 canard project http://www.abri.com/sq2000
Old January 9th 04, 05:28 AM
Richard Riley
On Thu, 08 Jan 2004 22:43:42 -0500, David O
:Other people use chunks of stainless or aluminum or wood. One I know,
:who's done a couple of nose landings, is putting a wheel from a roller
:blade just under the bumper so when it dies it will grind down to his
:"alternate gear system."
:Geez, it seems like a gear up warning system would be a better option
:for your friend. My pitot-actuated Long-EZ gear-up warning system
:saved me considerable embarrassment once. Without a gear-up warning
:system, it's not a question of if, it's a question of when. I decided
ne was mandatory for me after an airline pilot builder/flyer I knew
:landed his Long-EZ gear-up.
I absolutely agree with you on the warning system. For my bird I had
a pic chip custom programmed and a circuit board cut - the inputs
include airspeed, throttle, all three gear down and locked, canopies
both closed AND locked. I've been trying to figure out a good way to
do a squat switch for a couple of years but haven't found one. With
all three gear retracting, a gear up is both embarrassing and
expensive.
But in this case, my understanding is that both the nose landings were
the result of mechanical failure - a stripped gear, and a broken
NG3/4.
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Dumb Canard Question. Russell Kent Home Built 39 October 19th 03 03:25 PM
virgins (was: Question - Regarding Canard Pushers...) RobertR237 Home Built 1 August 10th 03 11:06 PM
Question - Regarding Canard Pushers... Tilt Home Built 33 August 10th 03 11:07 AM
Canard static port location Paul Lee Home Built 1 July 12th 03 02:55 AM
