Operating Limitations
Old January 31st 12, 04:30 AM posted to rec.aviation.soaring
ASM
Default Operating Limitations
To All,
Can someone email me a copy or a sample of the Operational Limitation
letter that needs to be send out to the FAA? I am guilty of not doing
that and would like to correct this problem. I am talking about a
letter that will permit operation of an experimental glider within a
300 nm radius from someone's home airport, participating in contests,
etc. Any help in this matter would be and will be greatly appreciated.
My email is jacek dot kobiesa at raypolandandsons dot com
Jacek
Pasco, WA
Old January 31st 12, 05:10 AM posted to rec.aviation.soaring
Tony[_5_]
On Jan 30, 10:30*pm, ASM wrote:
To All,
Jacek
Pasco, WA
http://www.ssa.org/test/docs/govnews/ProgramLetter.doc
Old January 31st 12, 12:10 PM posted to rec.aviation.soaring
Dave Nadler
Default Program Letter ( Operating Limitations)
It's called a "Program Letter".
I've emailed mine to you directly;
you'll need to find your local FAA contact for this.
Hope this helps,
Old January 31st 12, 03:34 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 30, 9:30*pm, ASM wrote:
To All,
What does it say in your Operating Limitations? If those do not
specify the need for a Program Letter then none is required.
I do have to send one in but I swear they sit on the FAX until the
cleaner throws them out. Never seen any response from the FSDO. (and
that's good)
Email me (reply to author) if you want a copy of my last one.
Andy
Old January 31st 12, 04:34 PM posted to rec.aviation.soaring
Mike the Strike
To All,
What does it say in your Operating Limitations? *If those do not
that's good)
Andy
I have a letter in a format different from that on the SSA site that I
obtained from another FAA source. Since my glider was examined last
year, I now have a dedicated examiner at my local FSDO and he
confirmed receiving my program letter last year. Some do get looked
at!
Old January 31st 12, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
Email sent. For anyone else interested, I contacted the FSDO by phone and
we discussed what was needed. After I had my letter prepared, I called him
back and, while on the phone, emailed the letter directly to him. He
received it and put it on file immediately. YMMV
Now I'll just update it annually.
"Andy" wrote in message
On Jan 30, 9:30 pm, ASM wrote:
To All,
that's good)
Andy
Old January 31st 12, 05:39 PM posted to rec.aviation.soaring
ASM
On Jan 31, 8:38*am, "Dan Marotta" wrote:
Email sent. *For anyone else interested, I contacted the FSDO by phone and
we discussed what was needed. *After I had my letter prepared, I called him
back and, while on the phone, emailed the letter directly to him. *He
received it and put it on file immediately. *YMMV
To All,
that's good)
Andy
Thank you. I replied to your email, but there is a Cerberus at the
gate restricting access to you.
Jacek
Old January 31st 12, 05:42 PM posted to rec.aviation.soaring
soartech[_2_]
What? Another government intrusion? Isn't a registration enough?
How ridiculous!
Did you hear the FAA just banned all commercial use of RC helicopters
for one year while
they figure out how they are going to regulate them.
Old January 31st 12, 06:32 PM posted to rec.aviation.soaring
Bob Kuykendall
How ridiculous!
Flying is a privilege, not a right. It bears further reflection that
the aircraft we're talking about here are experimental racing aircraft
that have not been tested to the certification criteria that have
applied to most aircraft since the 1930s. It seems reasonable that the
additional privilege of flying such craft over people's heads and
houses comes with a few minor strings attached.
Thanks, Bob K.
http://www.hpaircraft.com/hp-24
Old February 1st 12, 03:39 PM posted to rec.aviation.soaring
Dan Marotta
Just for the sake of argument, the LAK is certified to EASA standards (hope
I got the acronym correct). There was just not an effort at reciprocity
with the FAA. This was also the case with with three of my four previous
gliders.
Experimental makes it easier for us as owners, in my opinion, because we
don't have quite as many restrictions on maintenance and equipment as the
Standard aircraft. On the downside, we have to jump through the hoop of
annual Program Letters.
And, for the annual condition inspection, A&P mechanics are more plentiful
(and less expensive) than mechanics with Inspection Authorization.
"Bob Kuykendall" wrote in message
How ridiculous!
Thanks, Bob K.
FAA Operating Limitations rlovinggood Soaring 15 January 27th 10 08:35 PM
Gyrocopter requirements and limitations Andy L Piloting 1 October 28th 08 04:25 PM
Registering a Warbird with the FAA (Experimental Operating Limitations) [email protected] Owning 21 October 11th 05 01:52 AM
changing operating limitations pittss1c Home Built 46 August 22nd 05 04:28 AM
Limitations of Lemon Pledge Jay Honeck Owning 36 May 6th 04 08:44 PM
