O200 first run
Old May 12th 12, 06:53 PM posted to rec.aviation.homebuilt
Philippe[_5_]
Default O200 first run
Hello,
I just try to run my new overhauled engine with TAF-L oil filter
modification.. Oil pump is new.
I primed the oil pump, I oiled all the engine with an external
GM V8 oil pump throug the TAF-L inlet (6 qts), I checked the oil poured
at the oil pressure sensor hole before start.
And when I start the engine, no oil pressure after 1mn30s run.
I appreciate any indication...
thanks
Philippe Vessaire Ò¿Ó¬
C85 and O200 piston Philippe[_4_] Home Built 2 August 11th 10 05:47 PM
O200 overhaul Philippe[_4_] Home Built 0 May 30th 10 08:38 PM
O200 cylinder Philippe Vessaire[_3_] Home Built 3 October 19th 08 11:21 AM
O200 engine Philippe Vessaire Home Built 7 August 17th 07 08:53 PM
O200 nose Philippe Home Built 0 July 22nd 05 08:09 PM
