And Speaking of Side Tone
Old June 22nd 12, 05:07 PM posted to rec.aviation.soaring
Dan Marotta
Default And Speaking of Side Tone
Maybe someone on this board can offer a solution.
The Pawnee I fly when towing has side tone so loud that it's ear splitting.
I have to wear ear plugs under the headset to protect against the pain
caused by the side tone volume. The radio is a Terra with gas discharge
display and flip-flop frequency selection and a David Clark headset. I've
removed the radio from the rack and turned the side tone adjustment down as
far as it will go and it's still painful without earplugs.
Any suggestions would be appreciated.
BTW, the other towplane has an older model Terra and it has no side tone
whatsoever.
Old June 24th 12, 03:00 AM posted to rec.aviation.soaring
T[_2_]
caused by the side tone volume. *The radio is a Terra with gas discharge
display and flip-flop frequency selection and a David Clark headset. *I've
whatsoever.
Take the radio in to a radio shop and have them check it on the bench.
It could be that the pot you are adjusting has failed? They should be
able to set it and test it to factory specs.
T
HP310 and hx4705 - side by side, first impression Tuno Soaring 8 February 23rd 09 07:30 PM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
alarm tone in headset [email protected] Home Built 4 January 28th 05 12:28 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
