ILEC SN10 test version 2.37x4 available
Old July 25th 12, 02:16 PM posted to rec.aviation.soaring
Dave Nadler
Default ILEC SN10 test version 2.37x4 available
Version 2.37x4 is available. Tiny wind arrow
on moving map is the most visible change, fewer
warnings, clears many warnings automatically,
internal improvements, etc...
Also repairs a logger bug introduced in 2.37x1
(thanks Walt).
http://www.nadler.com/sn10/SN10_Resource_Index.html
I debugged and fixed 2.37x4 at Minden/Montague,
and flew with the changes at Montague. No issues
and downloaded the log using PClink and also USB
gadget daily.
Any testing / feedback is greatly appreciated !
Old August 14th 12, 07:55 PM posted to rec.aviation.soaring
Dave Nadler
I need more feedback prior releasing 2.37 !
eMail me directly...
Old August 14th 12, 08:21 PM posted to rec.aviation.soaring
JP Stewart
I'll load it an test this weekend.
JP
Old August 14th 12, 10:29 PM posted to rec.aviation.soaring
kirk.stant
On Tuesday, August 14, 2012 1:55:53 PM UTC-5, Dave Nadler wrote:
I need more feedback prior releasing 2.37 ! eMail me directly... Thanks, Best Regards, Dave "YO electric"
I flew with it (2.37x) for about 8 hours in 3 XC flights back in July and had no problems with it.
Sure would be nice to have easier AAT input/management...the new way to move the AAT turnpoint still leaves a lot to be desired, IMO!
And "start out the top" would be nice, too, despite what the SN10 manual says ("CDs not supposed to use start out the top...").
Cheers,
Kirk
66
Old August 15th 12, 06:20 PM posted to rec.aviation.soaring
Wheaton
Tried 2.37 for about 10 flights. Then dropped down to 2.36. Issues I recall we low voltage error message requesting reset, had 12volts using Ilec's check voltage after reset; winds not desplayed e.g. Profile or other screens; unexpected shut down. In all resets, not a problem on reset. 3.6 has been stable but for one reset low voltage message with still 12volts. Winds fine.
JJB
ILEC SN10 version 2.36 available Dave Nadler Soaring 1 May 5th 11 04:48 PM
ILEC SN10 beta test help needed Dave Nadler Soaring 0 February 25th 10 04:06 PM
ILEC SN10 and SN10B version 2.34 release Dave Nadler Soaring 0 September 21st 09 11:43 PM
ILEC SN10 release 2.33 available Dave Nadler Soaring 2 July 24th 09 02:22 PM
Ilec SN10 question John Ferguson Soaring 3 May 29th 07 05:11 AM
