Dark Side
Old July 30th 12, 09:08 PM posted to rec.aviation.soaring
Tony[_5_]
Default Dark Side
I have been to the dark side and can report that they do in fact have cookies.
http://www.onlinecontest.org/olc-2.0...l?dsId=2607034
http://www.onlinecontest.org/olc-2.0...l?dsId=2610937
Old July 30th 12, 09:33 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default Dark Side
That is a cirriously worrisome development.
T8
Old July 30th 12, 10:34 PM posted to rec.aviation.soaring
noel.wade
Default Dark Side
Next stop: Water-ballast!!! :-D
(C'mon, you've already jumped to fiberglass - all we're talking about
is a little H2O!) ;-)
Old July 30th 12, 11:23 PM posted to rec.aviation.soaring
Peter von Tresckow
Default Dark Side
Hmmm I thought that the Cherokee had a relief system, so water ballast is
covered
Pete
"noel.wade" wrote in message
Old July 31st 12, 12:05 AM posted to rec.aviation.soaring
Tony[_5_]
Default Dark Side
covered
Pete
yea eventually i'll get to that point, figured i ought to learn how to fly it dry first.
the only problem with the water system on the Cherokee is there is no in flight dumping option...8
Old July 31st 12, 12:19 AM posted to rec.aviation.soaring
Default Dark Side
;-) yea eventually i'll get to that point, figured i ought to learn how to fly it dry first. the only problem with the water system on the Cherokee is there is no in flight dumping option...8
Ballast? Fugeddaboudit. FLAPS!
Old July 31st 12, 02:45 AM posted to rec.aviation.soaring
Tony[_5_]
Default Dark Side
I have a modified BG-12 in the driveway (Neidrauer NG-1) so I can fly with flaps whenever I want to. I love the 5:1 glide with full flaps on approach. Exhilarating! I need to saw its wingtips down so that it is 15 meters instead of 50 feet though...
Old July 31st 12, 12:32 AM posted to rec.aviation.soaring
noel.wade
Default Dark Side
Hey its just wood... I've got a Makita, we can "fix" it! ;-)
--Noel
(who only recently started flying with water and is now strongly
tempted to do so every time the lift forecasts to be good)
Old July 31st 12, 08:10 PM posted to rec.aviation.soaring
Default Dark Side
On Monday, July 30, 2012 3:08:06 PM UTC-5, Tony wrote:
I have been to the dark side and can report that they do in fact have cookies. http://www.onlinecontest.org/olc-2.0...l?dsId=2607034 http://www.onlinecontest.org/olc-2.0...l?dsId=2610937
You are much more fun to fly with in the Cherokee :}
HP310 and hx4705 - side by side, first impression Tuno Soaring 8 February 23rd 09 07:30 PM
HP310 and hx4705 - side by side, first impression Darryl Ramm Soaring 0 February 22nd 09 02:42 AM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
