Capacity flask tube length
Old November 15th 12, 11:28 AM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Default Capacity flask tube length
I'm considering relocating my 0.45L capacity flask (for the vario) from behind the instrument panel to elsewhere in the cockpit. I would have to use maybe 6 or 7 feet of tubing to do that though...by some quick calculations, the extra tubing will make the 0.45L flask effectively almost 0.50L. Would this throw off my vario too much, or will it matter? Thanks
Old November 15th 12, 02:11 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
Thanks
you could reduce the volume of the flask to compensate, e.g. by putting
an adequately sized block of styrofoam into the flask.
Peter Scholz
ASW24 JE
Old November 15th 12, 04:37 PM posted to rec.aviation.soaring
John Galloway[_1_]
the vario) from
some quick
effectively
or will it matter?
Thanks
e.g. by putting
Peter Scholz
ASW24 JE
If it is a Winter flask I don't think it would be possible to
get the styrofoam in there.
A practical experiment with a 65" length of standard
instrument tubing, a measuring jar and water gives an
internal capacity of 29.7 mls for a 7 foot length. That
would add 6.6% to your capacity so all reading up and
down would be increased by that same amount. A 6 knot
thermal would read 6.4 knots. That wouldn't worry me.
The zero would remain the same. I would be more
concerned about making sure the tubing is fully supported
throughout its length.
John Galloway
Old November 26th 12, 10:46 PM posted to rec.aviation.soaring
Chip Bearden[_2_]
Time for another "in the old days" story. Many years ago when
diaphragm or bellows TE compensation was common (e.g., PZL,
Schuemann), tuning the capacity of the bottle and tubing to the
compensator was necessary. I had a Schuemann TE/netto compensator that
I loved, but had to mount it behind the cockpit. Since it incorporated
a .45l flask, I used much smaller diameter tubing to run to the vario
(no problems with delays). Others who had room to mount the
compensator near the vario would coil up many feet of the standard
instrument tubing to add capacity. The amount by which all of this
affected the accuracy of the vario was insignificant compared with the
effect on TE compensation. That's no longer an issue with TE probes so
I doubt you will be able to see any difference.
Chip Bearden
ASW 24 "JB"
USA
Small Sage vario and capacity flask For Sale John Bojack[_2_] Soaring 0 May 4th 09 05:34 PM
Bending brake capacity: 2024-T3 vs. mild steel? Ihab Awad Home Built 2 June 6th 05 09:50 PM
Vario flask insulation Bill Daniels Soaring 37 January 18th 04 12:49 PM
Battery capacity checker Roger Druce Soaring 12 October 24th 03 04:53 PM
Field capacity to repair, overhall, reconstuct, and build airplanes in W.W.I.I. John Freck Military Aviation 32 October 21st 03 06:08 AM
