Perhaps someone out in r.a.s land may be able to point me in the direction
of a commercial piece of equipment which would perform the following task. I would like to be able to charge up a 12 volt (nominal) gell cell battery and then plug it into a piece of equipment to check its total AmpHour capacity during discharge at some constant rate current (say the "10 hour" rate or the "20 hour" rate). All this towards assessing whether the battery has proven useful capacity and life left in it, or has it reached its discard date? The equipment would show the delivered amp-hours up to the point at which the voltage has fallen to a nominated end voltage. I realise that you can do it in a way with a light globe to discharge the battery and then time the length the light holds up glowing brightly. This is all too primative for this day and age, and there ought to be some piece of equipment available for the task. Or some circuit from an electronics hobby magazine?? Thanks in antcipation. Roger Druce |
In article , "Roger Druce" wrote:
Perhaps someone out in r.a.s land may be able to point me in the direction of a commercial piece of equipment which would perform the following task. I would like to be able to charge up a 12 volt (nominal) gell cell battery and then plug it into a piece of equipment to check its total AmpHour capacity during discharge at some constant rate current (say the "10 hour" rate or the "20 hour" rate). All this towards assessing whether the battery has proven useful capacity and life left in it, or has it reached its discard date? The equipment would show the delivered amp-hours up to the point at which the voltage has fallen to a nominated end voltage. I realise that you can do it in a way with a light globe to discharge the battery and then time the length the light holds up glowing brightly. This is all too primative for this day and age, and there ought to be some piece of equipment available for the task. Or some circuit from an electronics hobby magazine?? Thanks in antcipation. Roger Druce I built one myself. You find the schematic at http://www.ppc.ethz.ch/~peny/sf/ah_test.html Peter Nyffeler Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21 |
Hi Peter,
Good circuit ! However I have a couple of questions: 1. I presume the FET (Q2) will need a heatsink, as it will dissipate approximately 12W when discharging at 1 Amp ? 2. R9 should be 470 ohm, not 470 K Cheers, John G. "Peter Nyffeler" wrote in message ... | In article , "Roger Druce" wrote: | Perhaps someone out in r.a.s land may be able to point me in the direction | of a commercial piece of equipment which would perform the following task. | | I would like to be able to charge up a 12 volt (nominal) gell cell battery | and then plug it into a piece of equipment to check its total AmpHour | capacity during discharge at some constant rate current (say the "10 hour" | rate or the "20 hour" rate). All this towards assessing whether the battery | has proven useful capacity and life left in it, or has it reached its | discard date? | | The equipment would show the delivered amp-hours up to the point at which | the voltage has fallen to a nominated end voltage. | | I realise that you can do it in a way with a light globe to discharge the | battery and then time the length the light holds up glowing brightly. This | is all too primative for this day and age, and there ought to be some piece | of equipment available for the task. | | Or some circuit from an electronics hobby magazine?? | | Thanks in antcipation. | Roger Druce | | I built one myself. | You find the schematic at http://www.ppc.ethz.ch/~peny/sf/ah_test.html | | Peter Nyffeler | Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21 |
In article , "John Giddy" wrote:
Hi Peter, Good circuit ! However I have a couple of questions: 1. I presume the FET (Q2) will need a heatsink, as it will dissipate approximately 12W when discharging at 1 Amp ? 2. R9 should be 470 ohm, not 470 K Cheers, John G. John you are right. The FET needs a heatsink, as it works as a variable power resistor to provide a constant discharge current And R9 should have 470 ohm to turn on the monitor LED. Thanks Peter Peter Nyffeler Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21 |
Another question on Peter Nyffeler's circuit:
I think the part number for the dual operational amplifier is wrong. It should read "LM358" NOT "LM385". This last item is a precision voltage reference, not an amplifier. Cheers, John G. "John Giddy" wrote in message ... | Hi Peter, | Good circuit ! | However I have a couple of questions: | | | 1. | I presume the FET (Q2) will need a heatsink, as it will | dissipate approximately 12W when discharging at 1 Amp ? | | 2. | R9 should be 470 ohm, not 470 K | | Cheers, John G. | | "Peter Nyffeler" wrote in | message ... | | In article | , "Roger | Druce" wrote: | | Perhaps someone out in r.a.s land may be able to point me | in the direction | | of a commercial piece of equipment which would perform | the following task. | | | | I would like to be able to charge up a 12 volt (nominal) | gell cell battery | | and then plug it into a piece of equipment to check its | total AmpHour | | capacity during discharge at some constant rate current | (say the "10 hour" | | rate or the "20 hour" rate). All this towards assessing | whether the battery | | has proven useful capacity and life left in it, or has it | reached its | | discard date? | | | | The equipment would show the delivered amp-hours up to | the point at which | | the voltage has fallen to a nominated end voltage. | | | | I realise that you can do it in a way with a light globe | to discharge the | | battery and then time the length the light holds up | glowing brightly. This | | is all too primative for this day and age, and there | ought to be some piece | | of equipment available for the task. | | | | Or some circuit from an electronics hobby magazine?? | | | | Thanks in antcipation. | | Roger Druce | | | | I built one myself. | | You find the schematic at | http://www.ppc.ethz.ch/~peny/sf/ah_test.html | | | | Peter Nyffeler | | Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21 | |
"Roger Druce" wrote in message u... Perhaps someone out in r.a.s land may be able to point me in the direction of a commercial piece of equipment which would perform the following task. I would like to be able to charge up a 12 volt (nominal) gell cell battery and then plug it into a piece of equipment to check its total AmpHour capacity during discharge at some constant rate current (say the "10 hour" rate or the "20 hour" rate). All this towards assessing whether the battery has proven useful capacity and life left in it, or has it reached its discard date? Check http://www.laaudiofile.com/elkbltv2.html for a quick review and then search Google for ELK battery tester. My company uses these to test batteries in the field. While the ELK tester won't do all the things you asked, it tests batteries quickly and gives, in my experience, an accurate assessment of the battery's remaining life. And at just over $100 USD, it's not that expensive. -- bumper - ZZ "Dare to be different . . . circle in sink." to reply, the last half is right to left --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.525 / Virus Database: 322 - Release Date: 10/9/2003 |
"Roger Druce" writes:
I would like to be able to charge up a 12 volt (nominal) gell cell battery and then plug it into a piece of equipment to check its total AmpHour capacity during discharge at some constant rate current (say the "10 hour" rate or the "20 hour" rate). All this towards assessing whether the battery has proven useful capacity and life left in it, or has it reached its discard date? The equipment would show the delivered amp-hours up to the point at which the voltage has fallen to a nominated end voltage. At the research lab I work at, we use a power resistor (for the load) and a strip chart recorder (Vout/time). Steve |
Looks like a good project, what should the value of R7 be ?
Chris Runeckles Western Australia "Roger Druce" wrote in message u... Perhaps someone out in r.a.s land may be able to point me in the direction of a commercial piece of equipment which would perform the following task. I would like to be able to charge up a 12 volt (nominal) gell cell battery and then plug it into a piece of equipment to check its total AmpHour capacity during discharge at some constant rate current (say the "10 hour" rate or the "20 hour" rate). All this towards assessing whether the battery has proven useful capacity and life left in it, or has it reached its discard date? The equipment would show the delivered amp-hours up to the point at which the voltage has fallen to a nominated end voltage. I realise that you can do it in a way with a light globe to discharge the battery and then time the length the light holds up glowing brightly. This is all too primative for this day and age, and there ought to be some piece of equipment available for the task. Or some circuit from an electronics hobby magazine?? Thanks in antcipation. Roger Druce |
"Roger Druce" wrote in message u... Perhaps someone out in r.a.s land may be able to point me in the direction of a commercial piece of equipment which would perform the following task. I would like to be able to charge up a 12 volt (nominal) gell cell battery and then plug it into a piece of equipment to check its total AmpHour capacity during discharge at some constant rate current (say the "10 hour" rate or the "20 hour" rate). All this towards assessing whether the battery has proven useful capacity and life left in it, or has it reached its discard date? The equipment would show the delivered amp-hours up to the point at which the voltage has fallen to a nominated end voltage. I realise that you can do it in a way with a light globe to discharge the battery and then time the length the light holds up glowing brightly. This is all too primative for this day and age, and there ought to be some piece of equipment available for the task. Or some circuit from an electronics hobby magazine?? Thanks in antcipation. Roger Druce If cost is no problem, then look at the modern chargers that the RC flyers use. The better chargers measure the discharge and charge capacity of batteries/accus. Look for brand names like Schulze, Orbit and Graupner. Price level 100 - 300 eur depending about the charger model. regs, Jyrki |
On Tue, 21 Oct 2003 11:23:28 GMT, "JTH"
wrote: "Roger Druce" wrote in message u... Perhaps someone out in r.a.s land may be able to point me in the direction of a commercial piece of equipment which would perform the following task. I would like to be able to charge up a 12 volt (nominal) gell cell battery and then plug it into a piece of equipment to check its total AmpHour capacity during discharge at some constant rate current (say the "10 hour" rate or the "20 hour" rate). All this towards assessing whether the battery has proven useful capacity and life left in it, or has it reached its discard date? The equipment would show the delivered amp-hours up to the point at which the voltage has fallen to a nominated end voltage. I realise that you can do it in a way with a light globe to discharge the battery and then time the length the light holds up glowing brightly. This is all too primative for this day and age, and there ought to be some piece of equipment available for the task. Or some circuit from an electronics hobby magazine?? Thanks in antcipation. Roger Druce If cost is no problem, then look at the modern chargers that the RC flyers use. The better chargers measure the discharge and charge capacity of batteries/accus. Look for brand names like Schulze, Orbit and Graupner. Price level 100 - 300 eur depending about the charger model. regs, Jyrki Better yet, check any RC electric flight magazine (Quiet Flight for instance) and take a look at the charger/cyclers they're using for the electric power systems. The rapid charge facility probably isn't necessary for us, but the batteries these chargers are dealing with are nearer our battery sizes than the ones used for standard RC transmitters and receivers. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
| Thread Tools | |
| Display Modes | |
| RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 02:19 AM |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 03:38 PM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 10:12 PM |
