Connecting to a Nexus 7
Old November 29th 12, 10:04 PM
Lucky812 Lucky812 is offline
Junior Member
First recorded activity by AviationBanter: Jul 2012
Default Connecting to a Nexus 7
Has anyone tried to connect a Nano, PowerFlarm, or V7 vario to a Nexus 7?
Thanks
ES
Old November 30th 12, 09:42 AM posted to rec.aviation.soaring
Tobias Bieniek
Not to a Nexus 7, but to other Android devices and it works as expected. You can use either Bluetooth or a IOIO board for that.
Old November 30th 12, 01:46 PM
Junior Member
Is an IOIO board a "plug and play" type of hardware. Can I plug it in and configure the ports in the android device? I saw a video on youtube with a Colibri II, V7, and Dell Streak.
Old November 30th 12, 06:13 PM posted to rec.aviation.soaring
Shannon Madsen
I'd suggest taking a look at IOIO, plus the UART extension designed by SoarTronic. (http://www.soartronic.com) There's a little DIY involved, but these solutions are well tested with various android devices.
Old December 1st 12, 09:32 PM posted to rec.aviation.soaring
Rhubarb[_2_]
Lucky812
The IOIO is plug and play in the sense that you do not need to load any special firmware for gliding purposes. The standard firmware should be used. However it will require some soldering, mounting in a box etc. The soartronic shield probably reduces the soldering work considerably
New Nexus 7 with xc soar. glider12321 Soaring 29 December 17th 12 04:27 PM
Nexus program of any use flying? Paul kgyy Piloting 3 September 9th 08 06:47 PM
Connecting a GNS 430/530 to a PC PA34 F-GFTF Instrument Flight Rules 5 September 26th 04 07:09 PM
Connecting a GNS 430/530 to a PC PA34 F-GFTF General Aviation 4 September 26th 04 07:09 PM
Connecting a GNS 430/530 to a PC PA34 F-GFTF Aviation Marketplace 7 September 25th 04 04:38 AM
