SeeYouMobile SN-10 Wind Value?
Old January 23rd 13, 03:54 PM posted to rec.aviation.soaring
John C
Default SeeYouMobile SN-10 Wind Value?
Been unable to post to Naviter forum so asking here...
I am using SeeYouMobile 4.34. I have SN-10 properly wired to PDA and SeeYouMobile set to SN-10 for hardware setting. Will SeeYouMobile use the SN-10 wind value (from NMEA data) for its final glide calculation?
Thanks in advance for reply!
John
Old January 23rd 13, 04:04 PM posted to rec.aviation.soaring
K
John,
It is my understanding that you are correct. I have my GPS to the SN10 and the SN10 sending winds and Vario to the Oudie.
Old January 23rd 13, 05:01 PM posted to rec.aviation.soaring
John C
John,
Thanks "K"...I guess what I'm concerned about is whether SeeYouMobile actually *uses* that received wind value for final glide calcs.
John
Old January 23rd 13, 05:45 PM posted to rec.aviation.soaring
waremark
Incidentally which wind algorithm would you trust more, that from SYM or that from SN10?
I would expect SYM to make its own wind calculation but that is only a guess.
Old January 23rd 13, 05:56 PM posted to rec.aviation.soaring
Paul Remde
Hi John,
Yes. The versions of SeeYou after about March of 2012 do use the SN10 wind
data. It was requested by Gordon Boettger and provided by Naviter very
quickly. Gordon confirmed that it worked great. If I remember correctly,
the SN10 also sends out a number that represents how reliable the wind data
is and SeeYou Mobile uses that number to determine whether or not to use the
SN10's wind data.
Paul Remde
Cumulus Soaring, Inc.
_____________________________
"John C" wrote in message
John
Old January 25th 13, 11:56 AM posted to rec.aviation.soaring
John C
It's my understanding that SN-10 NMEA data doesn't provide airspeed. So I would prefer SYM to use the SN-10 wind value for its final glide calcs. I've been unable to find any SYM documentation, posts, etc. indicating this is the case. Hoping someone visiting this forum may have that answer...sent similar question to Naviter support, but haven't heard back.
John
Old January 25th 13, 04:35 PM posted to rec.aviation.soaring
John C
John
Andrej responded from Naviter support. Thanks Andrej!
"Yes and no. We do not use the wind as calculated in the SN10. Instead we read Indicated Airspeed and calculate our own wind.
Any other vario which sends IAS/TAS information will give the same winds in SeeYou Mobile."
Old January 25th 13, 05:52 PM posted to rec.aviation.soaring
Max Kellermann[_2_]
How can one read IAS from the SN10 when the SN10 does not send IAS?
Old January 26th 13, 04:50 AM posted to rec.aviation.soaring
Paul Remde
Hi,
I think the reply posted below from Andrej was from before they implemented
full support for SN10 winds in SeeYou Mobile. SeeYou Mobile does now use
the SN10 wind data.
Paul Remde
that from SN10?
guess.
John
SeeYou Mobile."
Old January 30th 13, 11:58 AM posted to rec.aviation.soaring
Naviter Info
Oops. Totally my bad. What Paul says is correct.
My answer is valid for everything else other than the SN10. Sorry about that.
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) JR[_2_] Aviation Photos 0 August 13th 08 09:36 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
Wind john smith Piloting 11 October 25th 05 04:05 AM
'tis an ill wind, etc ... Cub Driver Piloting 0 September 18th 04 11:04 AM
