Thanks to everyone for help in the best way to get over ATL. I had a total
of 3 hops over the "big" airport and one around it. ATL approach was great in giving me a clearances (class B and IFR) in the air even though they were swamped. ATL center helped a lot getting around yesterday's weather. It was great races and great flights with a lot of firendly help. A special thanks to Chip for his insight. |
"Kevin Chandler" wrote in message ... Thanks to everyone for help in the best way to get over ATL. I had a total of 3 hops over the "big" airport and one around it. ATL approach was great in giving me a clearances (class B and IFR) in the air even though they were swamped. ATL center helped a lot getting around yesterday's weather. It was great races and great flights with a lot of firendly help. A special thanks to Chip for his insight. I wonder when you flew through, Kevin? We had a massive staffing problem at the ARTCC on Sunday. In the ARTCC North Departure area, we only had 7 CPC controllers on the day shift (minimum number is 13) and 8 on the evening shift (minimum number is 15). This with six sectors open in the Area. We even had the evening shift supervisor call in sick, causing the day shift supe to face a 20 hour work day, hehehe. The reason I mention this is that when the race ended and the Nascar Air Force launched, the ARTCC faced an ATC Armeggedon with the crush of extra departures and not enough controllers to work the load safely. We couldn't even open a (seventh) sector that is required to be open for the procedures to work as planned, and it was quite literally uncontrolled chaos on our side of the mic between 1430 and 1630 local out there north of the Atlanta Class B. Did you notice? Chip, ZTL |
On 3/15/04 3:09 PM, in article
et, "Chip Jones" wrote: I wonder when you flew through, Kevin? We had a massive staffing problem at the ARTCC on Sunday. In the ARTCC North Departure area, we only had 7 CPC controllers on the day shift (minimum number is 13) and 8 on the evening shift (minimum number is 15). This with six sectors open in the Area. We even had the evening shift supervisor call in sick, causing the day shift supe to face a 20 hour work day, hehehe. The reason I mention this is that when the race ended and the Nascar Air Force launched, the ARTCC faced an ATC Armeggedon with the crush of extra departures and not enough controllers to work the load safely. We couldn't even open a (seventh) sector that is required to be open for the procedures to work as planned, and it was quite literally uncontrolled chaos on our side of the mic between 1430 and 1630 local out there north of the Atlanta Class B. Did you notice? Chip, ZTL I (barely, after a 15 minute wait on the ground) got on an IFR plan at 4:30 local, was turned over to 133.1 with a squawk code, then 133.1 snapped at me to get back on 121.0, we explained our situation and were handed back to 121.0 anyway. He took us to RYY for the ILS and wouldn't take us back after we went missed. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic www.wizardofdraws.com www.cartoonclipart.com |
I did not even notice any problems. I probably left 4A7 at 1730. I ended
up taking an indirect route home due to icing around TYS. We found a soft spot in the front at CHA and then turned north. I actually came into ATL on Saturday and stayed with friends at RYY and saw the Truck race on Saturday. Thanks, Kevin "Chip Jones" wrote in message ink.net... "Kevin Chandler" wrote in message ... Thanks to everyone for help in the best way to get over ATL. I had a total of 3 hops over the "big" airport and one around it. ATL approach was great in giving me a clearances (class B and IFR) in the air even though they were swamped. ATL center helped a lot getting around yesterday's weather. It was great races and great flights with a lot of firendly help. A special thanks to Chip for his insight. I wonder when you flew through, Kevin? We had a massive staffing problem at the ARTCC on Sunday. In the ARTCC North Departure area, we only had 7 CPC controllers on the day shift (minimum number is 13) and 8 on the evening shift (minimum number is 15). This with six sectors open in the Area. We even had the evening shift supervisor call in sick, causing the day shift supe to face a 20 hour work day, hehehe. The reason I mention this is that when the race ended and the Nascar Air Force launched, the ARTCC faced an ATC Armeggedon with the crush of extra departures and not enough controllers to work the load safely. We couldn't even open a (seventh) sector that is required to be open for the procedures to work as planned, and it was quite literally uncontrolled chaos on our side of the mic between 1430 and 1630 local out there north of the Atlanta Class B. Did you notice? Chip, ZTL |
| Thread Tools | |
| Display Modes | |
| Oil Leak on top of the engine -- follow up | Jay Honeck | Owning | 6 | February 13th 05 02:50 PM |
| How Many Nations Follow the FAA? | Charles Talleyrand | Owning | 15 | December 12th 04 05:17 AM |
| LEFT WINGERS IN FOR BIG SURPISE - STROKES TO FOLLOW ELECTION | Jarg | Military Aviation | 3 | April 20th 04 07:37 PM |
| Follow up Alright, All You Dashing, Swaggering Bush Pilots | wmbjk | Home Built | 135 | September 8th 03 07:09 AM |
| Follow up on fuel drains | Mike Noel | Owning | 2 | August 27th 03 02:51 PM |
