Sticking winter vario
Old August 21st 13, 06:15 PM posted to rec.aviation.soaring
Ian Reekie
Default Sticking winter vario
I have a 10+ year old 57mm Winter vario that has just started sticking when
it reaches its full positive deflection. A gentle tap on the glass
releases the needle.
I guess it will need a trip to Winter this winter (no joke intended).
Out of curiosity, does anyone know what causes this sticking and has
anyone successfully fixed this problem in the past.
Many thanks
Ian
Old August 21st 13, 06:54 PM posted to rec.aviation.soaring
Jon Marshall[_2_]
sticking when
intended).
and has
Many thanks
Ian
Ian
Not an answer, but an endorsement of sending your vario to
Winter. We did all our mechanical instruments this year, a
somewhat lethargic 20 year old vario, a hatefully graunchy 20
year old altimeter and an ok ish 20year old asi.
All came back at very reasonable cost £120 each asi and vario
and £160 ish for the altimeter.
All came with a report in german and new form1. Now all work
as if new.
jon
Old August 22nd 13, 02:02 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
sticking when
intended).
and has
Many thanks
Ian
Ian
as if new.
jon
I have ventured inside a sticking Winter vario and found the needle bent just enough to hit the glass at full deflection. A gentle nudge inward did the trick. Also, the needle can be centered by slightly bending the counterbalance located on the other side of the pivot point. I too have had great service from Winter. I packaged up about 10 real old instruments and got back 7 reconditioned instruments at a reasonable price.
JJ
Old August 24th 13, 09:55 PM posted to rec.aviation.soaring
Ian[_2_]
We had the same symptoms in our 57mm Winter mechanical vario, after the
glider had been out of service for maintenance for a month or two. We
ignored it for a while and after 4 or 5 flights the problem went away.
That was a few years ago and the problem has not recurred.
I can only think that there was some condensation in our instrument
during the lay up and that some "internal ventilation" and/or solar
heating on the front panel dried it out again.
So maybe try and fix it by flying it!
another Ian
Old August 25th 13, 06:54 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
Try taking it home and putting it in the airing cupboard for a few days.
Doesn't always work but worth a try.
when
another Ian
Old August 25th 13, 02:32 PM posted to rec.aviation.soaring
Mike the Strike
The OP says it sticks after full deflection - I doubt that rarely happens in the UK. (..and you had better explain to our US readers what an airing cupboard is!) - perhaps 30 seconds in a microwave oven would do the trick?
Old August 25th 13, 03:05 PM posted to rec.aviation.soaring
John Firth[_4_]
Try putting it in a sealed jar with dry silica gel (blue).
If there is condensation this should dry it out.
JMF
when
another Ian
Old August 26th 13, 04:47 AM posted to rec.aviation.soaring
Frank Whiteley
On Sunday, August 25, 2013 8:05:29 AM UTC-6, firsys wrote:
Used bag of rice with a wet cell phone the other days. Back to normal in few hours. Rice was around. Not enough little bags of silica gel.
Frank
JMF
when
another Ian
Old August 26th 13, 06:51 PM posted to rec.aviation.soaring
bumper[_4_]
I know rice has been pressed into service as an emergency desiccant, but I don't think it's anywhere near as effective as silica gel. Do a Google search for more.
bumper
Winter 80mm vario Steve Soaring 5 March 9th 12 06:33 AM
Moisture in Winter Vario Wayne Paul Soaring 2 June 23rd 09 03:25 AM
Winter Vario # 5493 [email protected] Soaring 5 June 15th 08 02:11 PM
Looking for used SN-10 and Winter Vario Pov Soaring 0 October 8th 06 07:38 PM
Winter Vario [email protected] Soaring 2 August 17th 05 08:24 AM
