FS: Eccentric Assembly Tools
Old December 8th 13, 11:17 PM posted to rec.aviation.soaring
SteveB_Z5
Default FS: Eccentric Assembly Tools
Do you have trouble getting your wings in place that last little bit to
insert the wing pins? Then this is the tool you need. Nearly 100 tools have been supplied for 25 different glider models from 9 different manufacturers. Everything from wood to self-launchers. $80 in the US and $95 outside the US. Shipping included.
See www.z5mfg.com
Old December 11th 13, 06:35 AM
Eurofighter Eurofighter is offline
Junior Member
First recorded activity by AviationBanter: Oct 2011
Very useful tool!
Old December 11th 13, 05:07 PM posted to rec.aviation.soaring
son_of_flubber
I can see how this tool would be very useful, but with all this experience have you seen any elongation of the bushing in the spar? If I understand how this works, it applies a concentrated load where the smaller diameter of the tool contacts the larger diameter of the bushing. The tool is hard and the bushing is relatively soft? How is this tool not a reamer? http://en.wikipedia.org/wiki/Reamer
Old December 11th 13, 05:47 PM posted to rec.aviation.soaring
Soartech
The tool is made of a metal which is much softer than the sintered bronze bushings used commonly in spar pin holes.
I have one and it helps some. I am still rather ****ed that I usually have to ask for some big guy with huge arms to put the pins in. There must be some secret to this step.
Old December 11th 13, 06:12 PM posted to rec.aviation.soaring
See www.z5mfg.com
See www.z5mfg.com
Old December 11th 13, 06:30 PM posted to rec.aviation.soaring
The one I use is machined out of a hard plastic - I think nylon. Works great.
9B
Old December 11th 13, 07:27 PM posted to rec.aviation.soaring
Dave Nadler
Say WHAT ? 4 different vendors I know all use plastic.
It's very, very technical:
Line up the wings prior trying to insert the pins.
Look inside the holes and make sure they are lined up !
Adjust by height of fuselage and/or wings.
BEFORE trying to jam in the pins.
These tools are only useful if the wings are close
to properly aligned, and especially to pull the wings
together the last little bit.
Hope that helps,
Best Regards, Dave
PS: Use of incorrect grease (or none, or dirt) will
also make inserting the pins extremely hard...
Old December 11th 13, 10:44 PM posted to rec.aviation.soaring
son_of_flubber
On Wednesday, December 11, 2013 2:27:05 PM UTC-5, Dave Nadler wrote:
The tool is made of a metal?
So the plastic deforms to the shape of the bushing and spreads out the load.
Old December 12th 13, 02:53 AM posted to rec.aviation.soaring
SteveB_Z5
In a past thread about these tools I remember someone saying they had a metal tool. The tools I make are made of Delrin plastic.
From McMaster-Carr:
Wear- and Water-Resistant
Delrin® Acetal Resin
Considered the workhorse of plastics, Delrin® acetal resin combines moisture resistance and a slippery, wear-resistant surface with an ability to hold tight tolerances. Often used for gears, bushings, impellers, and other parts that require its strength and rigidity.
I have used one of these tools in well over 250 assemblies of my DG-200 with no sign of wear in the bushings.
Steve Z5
http://www.z5mfg.com/
FS: ECCENTRIC ASSEMBLY TOOLs SteveB_Z5 Soaring 17 March 22nd 13 07:40 PM
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 July 27th 12 11:52 PM
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 January 21st 12 05:37 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
