Komet wheel bearing info - wanted
Old March 24th 14, 06:47 PM posted to rec.aviation.soaring
Default Komet wheel bearing info - wanted
The bearings for my 1986 Komet III trailer are part numbers:
30206 for the inner taper bearing and
30205 for the outer taper bearing.
Apparently these parts are available through AutoZone and probably lots of others.
What I'm missing is a part number for the seal between them. Four years ago, the mechanic did a lot of careful pounding to get the old seals out in reusable shape. I would like some replacements on hand this time.
Can anyone post the part number?
Just FYI, a mechanic I spoke with said a dragging brake could be the cause of the heat issue I'm having.
RF
Old March 25th 14, 03:25 AM posted to rec.aviation.soaring
Bastoune
RF,
Here is a link to the catalog for Knott, which is the manufacturer of the original axle. I misplaced the size of the brake assembly so you will have to find it. There should be a nameplate with a part number on the axle that can get you started.
Catalogue
http://www.knottbrake.com/pdf5/Spare...ailer_2007.pdf
or Website:
http://www.knottbrake.com/axles.html (then click on Service part catalog).
Note that the catalogue also includes the part for the tongue assembly which can become handy at some point. A Komet III should have a KR 13/7 C4 tongue. Page 86 (or 164 in the pdf) gives you the tongue spare part info.
I have not ordered parts from Knott USA just yet. I hope somebody on RAS has and can report if these parts are easy to procure from them. I don't think the seal you are looking for is available at a local auto part store.
Good luck.
Cobra wheel bearing info Paul Villinski Soaring 6 December 21st 14 10:07 PM
Where to buy a jockey wheel for a Komet trailer in Berlin? Morteza Ansari Soaring 4 August 6th 13 02:07 AM
Wanted: Cobra, Komet, Avionic, or Swan Trailer! NEEDTRAILER Soaring 3 October 24th 12 04:02 AM
Komet trailer wheel bearings Dan[_6_] Soaring 7 February 9th 09 06:13 AM
Komet III wheel info Gary Emerson Soaring 2 February 4th 09 03:14 AM
