resetting mixture
Old June 24th 04, 06:32 AM
xerj
Default resetting mixture
Generally speaking, when making power changes in the cruise once leaned, do
you just adjust your throttle and/or RPM and THEN adjust mixture? I imagine
you wouldn't push mixture to full rich before making power changes at
altitude. Is this the case?
Further question: when going from, say, 24 inches and 2500 RPM leaned to 21
inches and 2500 RPM, would you generally need to adjust mixture at all?
Thanks in advance.
Old June 24th 04, 06:46 AM
Michael 182
"xerj" wrote in message
do
imagine
21
Thanks in advance.
Do you have an EGT? Try making the changes and see if you are still running
the same degrees rich or lean of peak - whatever your engine requires.
Old June 24th 04, 08:14 AM
Peter Duniho
do
imagine
It's not really going to be an either/or situation, not necessarily.
First, it depends somewhat on how exactly I'm changing the power setting,
and what sort of airplane I'm in. My airplane is turbocharged, so if I push
the power to full, I'm going to push the mixture to full as well, and I'll
do so before changing the power setting. At low-altitude cruise in a
non-turbo aircraft, a similar procedure would apply.
If I'm making a minor adjustment to the power, I won't worry about the
mixture at all. If there's an EGT or TIT gauge, I'll keep an eye on that,
but otherwise I don't sweat it. By "minor" I mean something around 1" on
the MP gauge, or 100 RPM or less if it's a fixed-pitch prop.
For larger adjustments, I will adjust the power and then adjust the mixture.
This may, however, affect the power setting, which then may need tweaking
again (though probably to a small enough degree that I won't mess with the
mixture again).
21
One thing I left out of the above description is that I generally don't
bother touching the mixture at all on a power reduction, including for
descents. An exception would be if I were reducing the power to extend my
range, since obviously you'd want the most optimum mixture setting for that
power setting. Another exception would be if I'd descended to a new
altitude at which I expected to stay for some time at the new, lower power
setting. This would normally only happen if the new altitude turned out to
be bumpy, requiring a slower airspeed, or if I was flying IFR and ATC issued
a hold instruction or asked me to reduce my speed.
In the example you gave, without knowing anything else, I'd say I probably
wouldn't bother adjusting the mixture, but I might if I was going to remain
in cruise at that power setting for an extended length of time.
Pete
Old June 24th 04, 01:32 PM
tony
Thanks in advance.
In general, if you're increasing RPM, I'd recommend prop then throttle then
mixture.
If you're decreasing, consider throttle, then prop, then mixture.
In all cases, your egt is your best friend. Besides all of your other best
friends, of course.
AJW
Old June 24th 04, 05:31 PM
Robert M. Gary
"xerj" wrote in message ...
If I'm adding power, I enriching the mixture, add the power and then
relean. Some engines (Cont.'s) will not provide much power at altitude
if you go full rich.
If you're going to stay at that power setting for awhile, it would be
a good idea. However, its not critical. The important thing is that
when you add power, you need to enrichen.
-Robert
V8 fuel flow Robert Bates Home Built 34 January 24th 05 03:41 AM
O-320 way rich after Major + 160HP conversion + Powerflow Dave Gribble Owning 17 April 3rd 04 05:04 AM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
Shakedown: Friction Lock for Old 172 Mixture Control: $60 jls Home Built 2 January 30th 04 01:05 AM
Turbo 182: correct mixture for final approach at high altitude? Barry Klein Piloting 38 January 15th 04 03:25 AM
