Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
Interested in Rotor Track and Balance? Go here...
Old August 10th 03, 10:38 PM
Glenn
Default Interested in Rotor Track and Balance? Go here...
www.rwas.com.au
Lots of info on track and balance theory, problems and a new system to
correct blade mis-matches.
No commercial affiliation here, just pointing you to some good info.
Old August 15th 03, 06:29 PM
Stu Fields
Glen: I appreciated the info. I got in there and while there was a bunch
of advertising for their "Master Blade" generator and comparison machine,
they had a bunch of good info. In spite of the fact that my blade
population is one set, I have used their concept of moment arms to re-do the
alignment and balancing of my blades. Instead of stringing the blades from
tip to tip, I now string between center of mass of each blade. Which with a
little thought was what I had hoped I was doing when I went from tip to tip.
I did find a small amount of difference in the chord wise c.g. of my blades
but little to no difference span wise.
Thanks again for your mentioning this source..
Stu
"Glenn" wrote in message
www.rwas.com.au
Wierd vibration -- Prop or engine, balance or not??? Chuck Owning 17 December 1st 04 02:12 PM
Weight and Balance Formula, Can one calculate the envelope Joe Wasik Piloting 12 September 29th 04 08:15 AM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
