Cambridge L-Nav problem -- runaway vario
Old July 7th 14, 06:02 PM
jherzog jherzog is offline
Junior Member
First recorded activity by AviationBanter: Oct 2011
Default Cambridge L-Nav problem -- runaway vario
I have a nagging, recurring problem with my trusty L-Nav. Occasionally, when I power the unit on, the lift tone sounds constantly, and the vario display is pegged at maximum lift (10 kts). It's clear that the problem is with the L-Nav, and not the electric vario display, as the tone continues to sound once the electric vario display is unplugged, and the problem continues once the vario is plugged back in.
Cycling power once or twice will sometimes, but not always, make the problem go away -- until the next time. Last Friday, the problem persisted for two hours, finally disappearing as mysteriously as it came. Once the L-Nav powers on correctly, it has always stayed operational for my entire flight.
Has anyone else experienced this, and found a solution?
Jordan
Old July 7th 14, 08:42 PM posted to rec.aviation.soaring
Paul Ruskin[_2_]
I had the same problem with my (similar) SNAV.
Turned out that the external temperature sensor cable, which went into the air duct and was flexed every time the canopy opened, had worn and shorted a couple of leads out.
Unplugged it from the back of the SNAV and the problem went away. Fixed the cable, and it stayed away.
Paul
Old July 8th 14, 06:46 PM
Junior Member
Paul
Thanks so much Paul. I will check my OAT probe wiring this weekend.
Jordan
Old July 8th 14, 01:32 PM posted to rec.aviation.soaring
Pete Startup[_2_]
Long time ago but I had a similar problem. Mine tended to stick at a random
figure, say 2kts up and would often occur after I'd done a pull up. The
LNav would then continue to work but around the new datum - very difficult
to fly when you have 2kts of audio as your datum! On the ground when the
problem occurred, even taking all the pipes off made no difference and I
seem to remember the fault lay in a sticking airspeed transducer. Don't
know if you can get these replaced any more.
Old July 8th 14, 06:53 PM posted to rec.aviation.soaring
Mike Oliver
I have exactly the same problem with my L Nav but over the season have
concluded that the problem is more likely to occur if there has been
dampness in the trailer. Over last winter it stopped when I put a
dehumidifier in the trailer. Over this summer it only happens after a few
wet days. but thats in UK type weather conditions. The summer has been
fairly dry by our standards and as you say cycling the power usually makes
it work fine.
Old July 9th 14, 10:53 AM posted to rec.aviation.soaring
Mike Oliver
I have exactly the same issue with my L-Nav and have concluded it is a damp
issue. The problem stopped when I put a dehumidifier in the trailer over
the winter but has recurred over this summer after a damp period. As you
say normally recycling the power stops the problem but I too have had
occassions when the unit simply screams climb for the whole flight.
Old July 13th 14, 06:27 AM posted to rec.aviation.soaring
John B[_2_]
Exactly similar symptoms in my old L-Nav.
I had to relight at a contest once because of it. In frustration I banged the side of the instrument panel and the L-Nav became normal. So, I took off and flew the flight without further problems.
Occasionally, the problem would recur....and banging it always cured it!
Never did anything more involved than that.
Maybe a bad internal ground? Loose circuit board? Who knows?
J4
Old July 13th 14, 01:14 PM posted to rec.aviation.soaring
JS
As many times as we've all used it, percussive maintenance is not the correct answer. Send it to ClearNav.
Old July 13th 14, 01:43 PM posted to rec.aviation.soaring
John Carlyle
The frustrating thing is that a fault amenable to percussive maintenance can be darned hard to isolate and fix permanently in the repair shop.
-John, Q3
Cambridge Vario adjustment? Fred Blair Soaring 2 May 18th 09 05:24 AM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Old Cambridge vario Pupo Terso (Std. Austria) Soaring 3 February 16th 06 07:53 PM
Old Cambridge Vario Wiring Stewart Hamey Soaring 3 November 10th 05 11:40 PM
Old Cambridge Vario Wiring Stewart Hamey Soaring 1 November 2nd 05 09:01 PM
