Crossfeed in LS8 wing tanks?
Old August 6th 14, 06:16 PM posted to rec.aviation.soaring
Alexander Swagemakers[_2_]
Default Crossfeed in LS8 wing tanks?
For the LS8-15 the inner tanks are filled first. For all LS8-18 versions the outer tanks need to be filled first for structural reasons. The the 18m retrofit actually includes changing the tank sequence (new pages in the manual and the lever sequence needs to be changed for dumping in the correct order).
I completed the TM 8006. At first it seemed impossible to work through the dumping valve. I mounted a lightbulb inside the wing, used a dentist mirror an some stiff wires to work. In the ende, with a bit of patience, sealing the crossfeed was actually not that difficult.
Crossfeed in LS8 wing tanks? [email protected] Soaring 5 February 10th 15 11:46 AM
fin/wing tanks freezing Matt Herron Jr. Soaring 34 June 10th 13 04:14 PM
Schleicher wing tanks Andy[_1_] Soaring 5 April 22nd 09 08:00 PM
Drains in Wing Tanks flybynightkarmarepair Home Built 9 April 8th 06 06:32 PM
Garmin GNS 430/530 crossfeed Resca General Aviation 0 February 2nd 06 09:45 AM
