Best adhesive remover/cleaner for wing tape
Old October 13th 14, 03:58 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Best adhesive remover/cleaner for wing tape
I've been using 3M General Purpose Adhesive Cleaner 08984 for decades,
but now I'm running low again and need more. Is there a better choice
for removing wing tape adhesive in particular, and various other
adhesives in general?
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old October 13th 14, 04:10 AM posted to rec.aviation.soaring
Dan Daly[_2_]
I use "Goof off" - a citrus-based cleaner - takes the residue right off, easy on the finish. Called "Goo gone" in Canada...
2D
Old October 13th 14, 03:13 PM posted to rec.aviation.soaring
Jim White[_3_]
email
me)
2D
De-solv-it in the UK
Old October 13th 14, 04:24 PM posted to rec.aviation.soaring
jfitch
email me)
I like LPS PreSolve, in a aerosol can. It is a citrus oil based product, smells good, doesn't evaporate too fast, leaves no residue, and doesn't seem to harm any plastic or paint. Much easier on paint, plastic, and your hands than 3M Adhesive Remover. You can get it from Enco.
Old October 13th 14, 04:43 PM posted to rec.aviation.soaring
Craig Funston
email me)
I've been using xylene for adhesive removal with good success. Available at the local hardware store in the US.
Old October 13th 14, 05:54 PM posted to rec.aviation.soaring
Bill D
2D
Be careful with Goof-Off. It will dissolve and remove lacquer graphics.
Old October 13th 14, 07:55 PM posted to rec.aviation.soaring
Goof Off and Goo Gone are most definitely not the same or similar products. Goo Gone is a citrus based product while Goof Off is a petrochemical based product (See MSDS at http://www.goofoffproducts.com//uplo...vers_MSDS.pdf).
RS
2D
Old October 13th 14, 09:38 PM posted to rec.aviation.soaring
Bob Kuykendall
Sawzall.
Old October 13th 14, 09:59 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Monday, October 13, 2014 3:38:07 PM UTC-5, Bob Kuykendall wrote:
Sawzall.
How about 6 inch 36 grit disc, 10,000 RPM grinder, Bob? Then, follow up with 100 grit to smooth out the deep scratches?
Old October 13th 14, 10:04 PM posted to rec.aviation.soaring
Tony[_5_]
i think i usually just wipe with some acetone or whatever highly toxic quickly evaporating solvent i have handy.
wing tape Colin Roney Soaring 44 August 13th 20 02:15 PM
Wing Tape Craig[_2_] Soaring 0 May 5th 11 05:09 PM
Wing Tape - Does Thickness Affect Performance? ContestID67 Soaring 87 February 1st 07 03:24 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
Wing cleaner Viperdoc Owning 27 July 15th 03 05:03 PM
