IGC-approval - LX Navigation LX Eos GNSS Flight Recorder
Old November 27th 14, 10:33 PM posted to rec.aviation.soaring
Ian Strachan
Default IGC-approval - LX Navigation LX Eos GNSS Flight Recorder
I am pleased to announce IGC-approval for the LX Navigation LX Eos GNSS Flight Recorder for "all flights" including world records. This is a smaller version of the LX9000 and has similar characteristics.
The IGC-approval document may be downloaded from the FAI/IGC web site or the GFAC web site, see below. A table of all IGC-approved Flight Recorders can also be downloaded, with links to individual IGC-approval documents for each type of Recorder.
There are now 50 different types of IGC-approved Flight Recorders from 18 different manufacturers.
If you own or fly with one of these, it is recommended that you download its latest IGC-approval document from one of the web sites given below, and to note any changes that may affect the way that you operate it.
The GFAC web site is : www.ukiws.demon.co.uk/GFAC
The table of all IGC-approved FRs with links to Approval Documents is at:
www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf
The document with the tables contains:
(1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents.
(2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of manufacturer name.
(3) a list of all IGC-approval activity from 1996 to the present day.
(4) a history of IGC GNSS Flight Recording.
Navigating the IGC web site:
http://www.fai.org/gnss-recording-de...ight-recorders
Scroll down to "IGC-Approved Flight Recorders - Approval Documents", then click on the box underneath the above heading which says:
"IGC-approval Documents for all IGC-approved Flight Recorders".
This will call up a list of documents, the first one being "IGC-approval tables" with links to individual Approval documents.
This is followed by individual IGC-approval documents in alphabetical order of manufacturer's name. Scroll down to the Recorder type and click on its name. The IGC-approval document will then download automatically to the directory that you have set for downloads, without being displayed on screen first.
IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders.
The Technical Specification is available through the igc-approved-flight-recorders web site above or directly from the GFAC web site:
http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf
The Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via www.fai.org/igc-documents
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC)
Old November 28th 14, 06:19 AM posted to rec.aviation.soaring
Ian Strachan
Ian Strachan
There was an error in line 1 of my original post, please ignore the words "This is a smaller version of the LX9000 and has similar characteristics". The LX Eos is a new design and is not related to any other type of IGC-approved Flight Recorder.
Ian Strachan
Chairman IGC GFA Committee
IGC-approval of the LXNAV Nano GNSS Flight recorder Ian Strachan Soaring 5 September 1st 10 02:41 PM
IGC-approval for Nielsen Kellerman ClearNav GNSS Flight Recorder Ian Strachan Soaring 2 May 26th 09 03:45 PM
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 08:00 PM
IGC-approval document issued for NT Easy GNSS recorder Ian Strachan Soaring 0 January 10th 07 09:31 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 08:08 AM
