tail rotor power
Old January 16th 05, 01:54 PM
Brien
Default tail rotor power
What is the % of power a tail rotor at max pedal input takes . Does a
Hughes 269 require the same tailrotor % of power to the 180 hp that a UH-1
of it's 1400hp?
Old January 16th 05, 05:48 PM
Dave Jackson
of it's 1400hp?
The Americans say 5 - 10%.
The Russians say 10 - 15%
Simon says " Drop the tail rotor and take rotorcraft to the next generation"
Old January 16th 05, 08:10 PM
Jim Carriere
of it's 1400hp?
I like your answer.
I'd always heard between 5-15%, approximately of course.
For the most accurate answer to that question, you'd really have to
talk to the engineers at Hughes (make that Boeing-MD nowadays) and
Bell. For a general answer, I'd say yes, they are probably pretty
similar.
Besides it depends in flight regime- the vertical fin makes a
difference hovering in a crosswind, flying at any speed.
Old January 17th 05, 12:09 AM
Steve R.
Hmmm, I don't really know one way or the other but I'd heard that the tail
rotor can take upwards to 25% of available power, depending on the
circumstances.
Getting rid of the tail rotor will improve power efficiency if you're
talking about a twin rotor, counterrotating system (tandom or coaxial) but
even a NOTAR consumes some power to combat torque. Whether or not it's more
efficient than a standard single main rotor / tail rotor helicopter, I have
no idea!
JMO, FWIW! :-)
Fly Safe,
Steve R.
"Jim Carriere" wrote in message
UH-1
of it's 1400hp?
generation"
I like your answer.
For the most accurate answer to that question, you'd really have to talk
to the engineers at Hughes (make that Boeing-MD nowadays) and Bell. For a
general answer, I'd say yes, they are probably pretty similar.
Besides it depends in flight regime- the vertical fin makes a difference
Old January 18th 05, 07:28 PM
Jim Burt
The NOTAR is less efficient in terms of power demand than a conventional
tail rotor, but offers other advantages. The amount of power drawn by the
tail rotor depends on the flight profile. Heavy lift operations require
huge amounts of anti-torque, which contributed to a series of failures of
Bell 42 deg. gearboxes in logging service some years ago (although the
logging operations typically exceeded flight manual limits, so you should
not consider the design defective for its original purpose). The vertical
fin does unload the tail rotor in flight, but makes it less efficient in
some hover regimes, in which "ringtail" and fenestron type systems are more
efficient.
"Steve R." wrote in message
circumstances.
more efficient than a standard single main rotor / tail rotor helicopter,
I have no idea!
JMO, FWIW! :-)
Fly Safe,
Steve R.
UH-1
of it's 1400hp?
generation"
I like your answer.
a general answer, I'd say yes, they are probably pretty similar.
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 07:18 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Owning 1 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Piloting 1 July 26th 03 11:34 AM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
