Oudie2 to EOS Connection
Old February 23rd 15, 08:10 AM posted to rec.aviation.soaring
Ventus2NZ
Default Oudie2 to EOS Connection
Oudie 2 to LX Navigation EOS.
Has anyone connected this combo together?
1- What cables did you use
2- What hardware did you select in the Oudie menu
3- Do you have a wiring diagram of the pinouts
4- Does connectme work for file download
5- What hardware did you select in connect me menu
6- What baudrate did you select
With thanks.
Old February 23rd 15, 06:14 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I have cables for connecting an LX EOS to an Oudie. You can see details
he
http://www.cumulus-soaring.com/lx.htm#LX-EOS
NOTE: Make sure you use the most recent EOS manual. The original version
had the wiring connections backwards for transmit and receive on several
ports.
I have EOS units in stock.
However, I haven't tested connection to an Oudie yet, so I can't answer all
of your questions below.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Ventus2NZ" wrote in message
With thanks.
Old February 23rd 15, 08:31 PM posted to rec.aviation.soaring
Ventus2NZ
Thanks for your answer Paul
I have downloaded ver 1.1 of the manual with the corrections you pointed out.
Old February 24th 15, 04:01 AM posted to rec.aviation.soaring
Ventus2NZ
OK, slowly making good progress with this.
I have yet to get a cable so I set it up using Bluetooth.
Oudie - Settings - Hardware = Others
Oudie - Settings - Input - Port settings, Start using serial com 4 to search for Bluetooth devices.
Oudie - Settings - Input - Bluetooth - Lookup
Once you have found the EOS, select "Pair" - Use 1234 as a pin number then select OK.
The Serial Port should automatically change to "Com5: (Bluetooth)
I set Baudrate to 38400 as this was set in the User Port in the EOS
Parity = None, Bits = 8, Stop bit = 1, Set DTR = Ticked, Set RTS = unchecked.
Select - OK in Serial Port Box - Select OK at bottom left.
This got the communication working between the EOS and the Oudie.
Oudie2 to LX Navigation EOS Ventus2NZ Soaring 0 February 23rd 15 08:06 AM
Problem updating Oudie2 to 6.0 kirk.stant Soaring 5 November 18th 14 03:10 AM
Oudie2 connection to LXnav V7 John Docherty[_2_] Soaring 4 October 16th 14 02:27 PM
Oudie2 Units in Stock Paul Remde Soaring 0 August 30th 12 03:14 PM
Oudie2's available again in the USA - Upgrades also available Paul Remde Soaring 0 August 20th 12 09:32 PM
