Beta Prop
Old August 9th 05, 11:22 AM
Rob Fonhof
Default Beta Prop
Hi All.
Just wondering if there are any props out there that can be used on an
experimental aircraft engine, ie:subaru or RX-8 Renesis, which have a beta
range. Don't even want to consider a certified unit as this would probably
cost more than the rest of the firewall forward components.
Thanks in advance,
Rob.
Melbourne Australia.
Old August 9th 05, 02:34 PM
Gig 601XL Builder
I believe both the Woodcomp and the IVO will go into Beta.
"Rob Fonhof" wrote in message
Hi All.
probably cost more than the rest of the firewall forward components.
Thanks in advance,
Rob.
Old August 9th 05, 08:13 PM
Dave S
I believe you are mistaken on the IVO.
The IVO has a specific range of travel that is accomplished by twisting
the blade midshaft, not rotating the entire blade in the hub.
Also, with the auto engines the original poster is discussing, it is
less a function of the engine and more a function of will the PSRU
(re-drive) support a hydraulic governor. The Marcotte and Mistral PSRU's
will support a hydraulic constant speed prop, others such as the Real
World Solutions brand will not.
An electric MT can be obtained that will run in the beta (and even
reverse) ranges, but that is a $10k US proposition. Of course, getting a
hydraulic governor, the price difference for a redrive that supports
one, and getting a hydraulic CS prop, you are likely there with the cost
of an Electric MT in the first place.
It costs money.. plain and simple.
The IVO may be an option for you, but as for a specific "beta" range, I
am fairly sure it doesnt have one.
Dave
Hi All.
Thanks in advance,
Rob.
Old August 9th 05, 08:28 PM
Dave S
Also if you are seriously contemplating the use of a rotary (RX7 or
RX8), I would seriously recommend subscribing to one or both of the two
listserv's or newsletters out the
FlyRotary: http://www.flyrotary.com/ , web archive viewable at
http://lancaironline.net/lists/flyrotary/List.html
This is the list where people are DOING things (more practical oriented)
and is a little less moderated.
Rotary Engine Newsletter, formerly the Aircraft Rotary Engine Newsletter:
http://www.rotaryeng.net
This is closely moderated by an engineering type in California, who
reviews each post before forwarding it. The focus here is much more
theoretical, and skewed toward peripheral ported rotary engines. On more
than one occasion the moderator has stated how something will "not work"
based on theory and analyses, only to have someone on the other list be
"doing it". Still worth following tho.
Dave
Dave
Hi All.
an experimental aircraft engine, ie:subaru or RX-8 Renesis, which
have a beta range. Don't even want to consider a certified unit as
this would probably cost more than the rest of the firewall forward
components.
Thanks in advance,
Rob.
Old August 9th 05, 09:15 PM
Gig 601XL Builder
"Dave S" wrote in message
nk.net...
I well could be plus in my head Beta means reversing. The reason for this is
when I was getting my helicopter rating the instructor used the term for
negative rotor pitch and it stuck in my head.
What would the point of this in a small plane be if not reversing?
I did find this definition for Beta.
Beta Control : A propeller which allows the manual repositioning of the
propeller blade angle beyond the normal low pitch stop. Used most often in
taxiing, where thrust is manually controlled by adjusting blade angle with
the power lever.
Old August 9th 05, 10:29 PM
Dave S
My understanding is that the beta range is descriptive of the pitch
settings below "flight idle" in turboprop engines.
For instance, on a King Air, flight idle provides enough thrust to go 80
kts or something like that down the runway (or taxiway) (repeating
heresay, not speaking factually)..
Placing the props into the beta range allows selection of a ground idle
setting, that keeps the pilot from having to ride the brakes on the ground.
Selecting beta range (thrust below flight idle is how I am defining it)
in flight could result in too-rapid a descent.
In piston engines I suspect this is not as major of an issue, as you can
throttle the engine down to reduce power.
To repeat about the Ivo, based on your assumption that beta means
reversing.. the IVO does NOT reverse.
Dave
Old August 10th 05, 03:48 PM
Gig 601XL Builder
nk.net...
ground.
Selecting beta range (thrust below flight idle is how I am defining it) in
You were right. I looked at the WoodComp and the IVO at about the same time
a couple of months ago. The WoodComp does reverse.
I have a feeling the OP, like myself was confusing Beta with Reverse. So my
original answer to him was half right.
Old August 10th 05, 03:50 AM
Jim Carriere
for this is
For a given beta pitch, the prop makes much more reverse thrust with
forward airspeed than when there is very little airspeed. This is
because of the angle of attack on the prop blades (aerodynamic
explanation using vectors).
The point is your landing rollout is greatly reduced, because the
prop provides a lot of deceleration immediately after touchdown when
the brakes are least effective (think, jam on the brakes too hard
when the wing is still making some lift, they lock up).
It's handy during taxiing when you can get no or slight reverse
thrust, that saves your brakes and is less workload when you get the
hang of it. It's usually a bad idea to reverse taxi- kick up fod
then roll through it as the engine ingests it, hard to see where
you're going, the nose (or tail) wheel may not castor 360 degrees...
to name a few reasons.
Old August 10th 05, 04:57 AM
Morgans
"Jim Carriere" wrote
It's handy (beta) during taxiing when you can get no or slight reverse
It is also -really- handy for seaplanes, who have *no* brakes. ;-))
Old August 10th 05, 08:21 PM
PittsS1C
Is it a good idea to have beta with any geared engines?
Aren't there typically problems with chattering the gears
back and forth leading to failures?
nk.net...
Also, with the auto engines the original poster is discussing, it is less
a function of the engine and more a function of will the PSRU (re-drive)
support a hydraulic governor. The Marcotte and Mistral PSRU's will support
a hydraulic constant speed prop, others such as the Real World Solutions
brand will not.
hydraulic governor, the price difference for a redrive that supports one,
and getting a hydraulic CS prop, you are likely there with the cost of an
The IVO may be an option for you, but as for a specific "beta" range, I am
Dave
Hi All.
beta range. Don't even want to consider a certified unit as this would
Thanks in advance,
Rob.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
