PTT wiring ?
Old April 21st 15, 07:55 PM posted to rec.aviation.soaring
Default PTT wiring ?
I have a Becker 4201 and I'm wiring up a PTT and vario switch in the stick grip.
Many people have posted that 22-24 tefzel is the stuff to use.
Should the wire be shielded?
Is there a "best" type of quick disconnect connector to use for this small guage wire. I was going to use a JST connector, although I have no idea how much current is running through the PTT or the V7 climb circuit...
Nick
Old April 21st 15, 10:08 PM posted to rec.aviation.soaring
Nick
Current in wires such as these is very small. Your're likely talking under an AMP at most.
So you know, "JST" makes a lot of connectors, so that info is sorta moot.
Take this from someone that worked in the wire & cable industry (manufacturing) for ~30 years.
PS, knowing WHAT "JST" connector would help us help you. ;-)
Old April 21st 15, 10:24 PM posted to rec.aviation.soaring
John Carlyle
All the PTT switch does is ground a logic gate, so unshielded 22-24 Tefzel is more than adequate. I personally wouldn't use a connector, just run from the switches to the connectors on the back of the Becker and the V7 (less to go wrong).
-John, Q3
Nick
Wiring in a KI 214 apachearmtguy General Aviation 1 November 10th 09 02:15 AM
wiring Jerry Wass Home Built 7 January 3rd 09 09:03 PM
Wiring Jerry Wass Home Built 1 January 2nd 09 03:44 AM
Wiring KX 175 TSO Tore B. General Aviation 0 May 6th 04 10:02 PM
Wiring KDR-510 Chad Lemmen Owning 3 September 16th 03 02:03 PM
