Filser Transponder Antenna .......
Old June 5th 15, 10:52 PM posted to rec.aviation.soaring
Ron Gleason
Default Filser Transponder Antenna .......
I have to change the transponder antenna on my V2CX to an external one. The choices are minimal and I am looking for feedback on the Filser Transflex-3.
It seems that this antenna is only available in Euopre, no USA vendors list it on their websites.
Are you using this antenna? Does the flexibility prevent damage? Can anyone from Europe recommend the a good place to purchase it online?
Thanks in advance
Ron Gleason
Old June 5th 15, 11:24 PM posted to rec.aviation.soaring
Hi Ron,
The short:
Yes
Yes
http://onlineshop.funkwerk-avionics....afcc5ae1b77dc6
The long:
I purchased the Transflex 03 from the online store above who promptly shipped it to the USA. Installed it into a Discus B in accordance with SH's tech note. You'll have to trim the ground plane a little to get it around the hardware in that area. The flexibility was significant. Not just enough to prevent damage in an outlanding but also a freak trailering accident, should one happen. I was very happy with this antenna (only 'was' as the glider has been sold)
CJ
Old June 6th 15, 01:31 PM posted to rec.aviation.soaring
Thanks in advance
Ron Gleason
I've installed this on my Ventus 2CXM and have had it for seven + years. Very happy with it. Functions very well. Also available from Streckenflug.at Placed on the right side of the belly of the fuselage to the side of the wheel well. Tight fit but proper preparation makes the install easy. Flexibility keeps it from being knocked off. I fly in the USA.
Transponder antenna installations Dick[_3_] Soaring 29 January 8th 20 06:08 AM
Transponder Antenna Rick Fuller Soaring 6 January 30th 08 06:03 PM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
Oil on transponder antenna Bob Owning 12 May 9th 04 08:59 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
