Trailer Vent Fan
Old September 20th 15, 12:01 AM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Trailer Vent Fan
I just checked two trailer vent fans and both were dead. With a little checking I found one had a dead battery and the other had a bad motor. They are both made by NICR and are day/night fans which employ a battery that charges all day, so it can run all night. Why did the battery go dead? I suspect it died because that trailer has been stored inside where the battery soon went to zero volts and there was no sunlight available to recharge it. This condition probably lasted all Winter long. There is an on/off switch, but I'm sure I would put the ship away and forget to turn the fan off or take it out and forget to turn it back on. Better for me to replace the fan with a day only unit made by SUNVENT which is a lot cheaper too......$60 vs $160. The other trailer will probably be left out most of the time and a working day/ night fan is required. Anyone know where to get a Ni Cd 2500 mAh 1.2v?
JJ
Old September 20th 15, 12:35 AM posted to rec.aviation.soaring
Andrzej Kobus
JJ
JJ, why would you want a fan to work 24 hours a day and not just at night when your trailer is parked outside? I am just curious. Temperature in a trailer would be higher than outside if air was not being exchanged at night, at that would be beneficial to reduce condensation potential. Am I missing something here.
Andrzej
Old September 20th 15, 01:58 AM posted to rec.aviation.soaring
JJ
I get all my R/C stuff from Dave Thacker at Radical RC in Huberville, OH. Very cheap shipping. http://www.radicalrc.com/shop/
Old September 20th 15, 02:28 AM posted to rec.aviation.soaring
JJ Sinclair[_2_]
The options on store bought equipment are; run the fan 24 hours a day OR run it day only. I don't see any reason to run it nights only? My idea has always been to let fresh air in low at the aft end and let (fan) it out high at the other end. Gets hot enough to peal Velcro inside the trailer, so any circulation has got to help.
JJ
Old September 20th 15, 02:45 AM posted to rec.aviation.soaring
JJ
I have used www.cheapbatterypacks.com for RC electric batteries for over a decade.
They can make custom packs (pretty much any voltage & chemistry) and are near Portland, OR.
Old September 20th 15, 03:58 AM posted to rec.aviation.soaring
Dave Springford
I have been happy with this unit in my trailer for the last 10 years.
No battery to go flat, works on solar with the fan and passively with a venturi-type design when there is no sun but there is wind.
http://www.jamestowndistributors.com...ct.do?pid=9494
Old September 20th 15, 12:53 PM posted to rec.aviation.soaring
Andrzej Kobus
JJ
JJ, I in my first sentence I intended to say day not night. Meaning why do you want to run a fan 24 hours a day instead of during the day only.
Old September 20th 15, 12:54 PM posted to rec.aviation.soaring
Andrzej Kobus
I just checked two trailer vent fans and both were dead. With a little checking I found one had a dead battery and the other had a bad motor. They are both made by NICR and are day/night fans which employ a battery that charges all day, so it can run all night. Why did the battery go dead? I suspect it died because that trailer has been stored inside where the battery soon went to zero volts and there was no sunlight available to recharge it.. This condition probably lasted all Winter long. There is an on/off switch, but I'm sure I would put the ship away and forget to turn the fan off or take it out and forget to turn it back on. Better for me to replace the fan with a day only unit made by SUNVENT which is a lot cheaper too......$60 vs $160. The other trailer will probably be left out most of the time and a working day/ night fan is required. Anyone know where to get a Ni Cd 2500 mAh 1.2v?
JJ
Andrzej
It was late when I wrote it. I mean why would you want a fan to work 24 hours a day and not just during during daylight hours.
Andrzej
Old September 20th 15, 02:07 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Hi Andrze,
I too think day only is the proper thing to do, but the manufacture had something in mind when they made the day/night unit. I thought they were all day only and was surprised to see they even had a battery. BTW, when the battery goes dead, it becomes a direct short to the solar cells and the thing won't run day or night, but, if you simply remove the dead battery, it works again in the day only mode.
Cheers,
JJ
New Vent! sisu1a Soaring 34 December 10th 10 12:59 AM
How to check functionality of solar vent on Cobra trailer? Matt Herron Jr. Soaring 10 September 27th 10 03:57 AM
JS-1 Exhaust Vent sisu1a Soaring 16 July 27th 10 03:32 AM
Tail Vent? jjcact Soaring 1 June 10th 05 03:10 PM
Eye Ball Vent B. Iten Soaring 4 September 4th 04 09:38 AM
