Looking for O2 equipment advice
Old November 11th 15, 05:11 AM posted to rec.aviation.soaring
Dave White[_2_]
Default Looking for O2 equipment advice
I recently purchased an older Schweizer with a built in O2 system. The bottle is a Catalina and would need hydrostatic testing. The regulator is an older military type A-14 certified to 45,000 feet last overhauled in 2001. The mask is well worn and would need replacing. I would appreciate advice whether to bring the current system up to standard or chuck it and look at Mountain High equipment. I fly out of Truckee or Minden and plan to fly XC next summer and possibly wave in the fall. Is it possible to put together a Mountain High rig with bail out bottle to do all of that or would I need one system for XC and another for wave flying? Is it worth the time, effort, and money to overhaul the installed A-14 system?
Thanks
Old November 11th 15, 04:09 PM posted to rec.aviation.soaring
Dan Marotta
It depends on whether, and how often, you want to fly much above 18,000'
MSL. The A-14 system will be an oxygen hog but, properly functioning,
will take you about as high as you care to go. It's neither as
comfortable nor economical as a Mountain High system. Practically
speaking, you'll do a lot more cross country flying than high altitude
flying. For my dollar, I'd get the MH system and fly within its
altitude capabilities.
Thanks
Dan, 5J
Old November 12th 15, 02:10 AM posted to rec.aviation.soaring
Christopher Giacomo
It is probably going to cost you roughly the same whichever way you go with it, so as dan stated, you need to decide what you want to do with the system. I overhauled my A-14 a few years ago, and it was in the ballpark of $6-700. You can certainly replace the mask with other surplus or new equipment, but should expect to spend $1-200 for a new high quality mask. I have found that some of the military masks can get painful on the bridge of your nose after wearing for a few hours, so that coupled with the A-14 sucking down O2 may drive you away from that route if you aren't searching for your double lennie.
Chris
Christopher Giacomo
Chris
Used equipment [email protected] Soaring 4 June 15th 15 12:50 PM
O2 equipment .... Ron Gleason Soaring 3 November 8th 11 12:11 PM
O2 equipment .... Ron Gleason Soaring 0 November 6th 11 09:24 PM
Oxygen equipment Roger Worden Soaring 1 May 9th 05 02:59 PM
tso equipment Air Methods Corporation Home Built 0 September 21st 03 07:41 PM
