Need Becker AR3201 Female 15 pin Latching Connector
Old December 17th 15, 03:27 AM posted to rec.aviation.soaring
Six-Seven Romeo
Default Need Becker AR3201 Female 15 pin Latching Connector
I am installing a used Becker AR3201 transceiver for a friend. It didn't come with a harness. I can make the harness myself and could use a standard DB-15 connector. However, I would prefer to use the latching type connector that Becker specifies and you can see on the AR4201 and AR6201 (which use a DB-25 instead of the needed DB-15). Does anyone know of a source for the DB-15 latching connector? Thanks, John
Old December 17th 15, 02:00 PM posted to rec.aviation.soaring
As you already know, the DB-15 connector itself is the same as all other DB-15 connectors - the difference is in the screw stud itself. I've never found a source for these studs but maybe a call to Becker would result in them sending you a couple. Barring that, you could certainly remove the studs from another discarded Becker harness, and install into your DB-15. You could easily make a set if you have access to a small hobbyist metal lathe. Or, worst case, get a couple of properly sized pan head screws and just file the heads down to the correct diameter and thickness. I have a harness with latch studs handy right now that I could take pictures and measure for you if necessary. Feel free to contact me off list if you need those details.
Robert
Old December 17th 15, 02:28 PM posted to rec.aviation.soaring
Latching? Like threaded fasteners? Look at electronics places online like Digikey or Newark Electronics.
They have screws, studs, standoff's (short piece with a male thread on one end and a female thread on the other end).
Shipping will likely be more than the part.
If you have a PC repair place near you, they may also have them.
Old December 17th 15, 04:54 PM posted to rec.aviation.soaring
Six-Seven Romeo
@Charlie M. This isn't a very common type of secure connection for D connectors that use a screen. There is a slide as part of the radio's male D connector that engages "studs" on the cable's female D connector.
All - I found that both Dittel and Becker use the same latching mechanism and Cumulus-Soaring.com has the Dittel version of the female D connector.
Old December 17th 15, 05:04 PM posted to rec.aviation.soaring
Six-Seven Romeo
Wow. That got messed up. Lets try again.
@Charlie M. This isn't the very common simple screw type of secure connection for D connectors. On the Becker radios there is a slide as part of the radio's male D connector that engages "studs" on the cable's female D connector.
Old December 17th 15, 05:18 PM posted to rec.aviation.soaring
Fair enough, just trying to say I have bought quite a few "D-type capturing devices" that can be sourced through the 2 listed sources.
Without seeing it, I can only guess.
Was only hoping it was a source to you.
Old December 17th 15, 08:16 PM posted to rec.aviation.soaring
Benedict Smith
part
female
D connector.
I have seen this type of latching connector quite often in ex military
radio
sets, however this is in the UK, it may be worth checking any military
surplus
stores to see what you can find.
Ben.
Old December 17th 15, 09:30 PM posted to rec.aviation.soaring
RobKol
What you looking for is a lock lever and locking tabs that are available from Positronic. Catalogue available at http://www.connectpositronic.com/?media_dl=2293 , page 28.
These usually require that Positronic backshell is also used.
They are excellent connectors. There are many distributors.
Robert
Old December 19th 15, 03:32 AM posted to rec.aviation.soaring
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Charlie M is right, I bought some from Newark Just last week,
"slide lock post assembly, Stock number 93f3701' Manufacturer number D53018..
Just a few cents each.
Good lift
Scott
Becker AR3201 Radio need help [email protected] Soaring 4 July 31st 14 03:06 AM
Becker AR3201 Lazarost Soaring 3 March 26th 13 06:16 AM
Becker AR3201 [email protected] Soaring 4 April 6th 09 11:15 PM
Wanted: Becker AR3201 Ira Blieden Soaring 0 December 14th 06 06:28 PM
Looking for a Becker AR3201 Ira Blieden Soaring 0 December 8th 06 01:38 PM
