Reading SGS 2-32 Polar Curve
Old March 15th 16, 09:25 PM posted to rec.aviation.soaring
runner4065
Default Reading SGS 2-32 Polar Curve
I'm struggling how to read the polar curve for an SGS 2-32. It can be found on page 19 of the flight manual found he
http://www.airsailing.org/downloads/...t%20Manual.pdf
What are the two different groups of lines? I'm only familiar with one (the top set).
Any significant in a band vs. a line?
Typically the origin (0,0) is in the top left with sink rate increasing as you move down on the Y-axis. This chart is different.
What is the L/D-S=7.44 or Vs-S=7.44?
My experience is minimum sink is a vertical line at the apex. So I believe at 1020 lbs, this would be about 53 mph.
Best L/D is typically a line from the top left (0,0) origin, or about 61 mph. But again, there is no 0,0 origin and I'm not sure what the L/D-S vs the Vs-S lines are.
Any help is appreciated.
Thanks
Old March 15th 16, 09:50 PM posted to rec.aviation.soaring
Michael Opitz
The bands are probably the result of data point scatter when they did
flight tests. For L/D and Min Sink speeds see page 9 of the manual -
depending on gross weight....
Old March 15th 16, 09:52 PM posted to rec.aviation.soaring
Papa3[_2_]
There are 4 curves in total: L/D solo (wingloading at 5.67 lbs/sqft) and dual (7.44 lbs/sqft). Those are read against the left Y axis. Sink rate solo and dual. Those are read against the right Y axis. As far as the bands, I suspect it's "truth in advertising" by Schweizer; i.e. "it's our calculated L/D so don't hold us to it" :-)
Old March 15th 16, 09:59 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
And the upper curves are the L/D curves. Well, upper at the left hand side of the chart. The lower curves are the sink rate curves.
Don't you just love the optimism of showing best speed to fly for next expected thermal of up to 1600 feet per minute!
Steve Leonard
Old March 15th 16, 10:10 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
To read the L/D curve, solo, the plane will have a best L/D of about 35 at a speed somewhere between 52.5 and about 56 MPH. The curve is fairly flat up there. L/D read from the left side scale, airspeed read on the horizontal axis.
To read the VS (vertical Speed) curve, for this same speed range, the VS will be roughly 2.1 to 2.4 feet per second (read from the Right side vertical scale). As you indicated, hard to tell from the VS curves exactly where best L/D occurs since they truncate the vertical and horizontal axis of the plot. Must be why they also show the L/D curves on the same chart.
I believe you would use the VS curve to draw the polar as you are use to seeing it. Complete with airspeed going all the way to zero (so you can more quickly do graphic analysis) and sink rate going all the way to zero. Lopping off the unobtainable portions of this graph allows a manufacturer to show a "flatter" polar, making you think the plane will not increase its sink rate rapidly as you increase the airspeed.
Hope this is more helpful than my previous reply.
Steve Leoanrd
Old March 15th 16, 11:04 PM posted to rec.aviation.soaring
runner4065
Helpful. Am I correct in assuming this L/D curve is interpreted differently than a polar curve? And therefore the apex of the curve is the best L/D, not a line touching the curve beginning at the origin?
How do I compensate for wind? If I have a 15 mph headwind, what becomes my best L/D?
Old March 15th 16, 11:25 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Correct. On the L/D curve, max L/D is the apex of the curve. On the "polar curve" as you describe (horizontal and vertical speeds), best L/D is a line drawn through the origin, tangent to the polar curve.
To see what affect wind has, you can take the existing chart, extend the airspeed to the left to find the zero airspeed, and the vertical speed down to zero vertical speed, and use this origin. It will be "upside down" from what you are use to, but you should be able to work with it, drawing tangents to find speeds to fly for various winds and anticipated climb rates.
Steve Leonard
Old March 16th 16, 08:07 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I love the cover of the manual - a series of nouns that together describe the entire experience of owning your own glider.
A.
Old March 16th 16, 08:10 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I love the cover of the manual - 3 nouns that together describe the entire experience of owning your own glider.
9B
Old March 16th 16, 05:48 PM posted to rec.aviation.soaring
kirk.stant
The whole flight manual is so quaint!
I had forgotten that Vne is higher with the dive brakes open (158) than closed (150), and is called "Max Glide Speed". Are you still technically gliding when going straight down standing on the rudder pedals? (BTDT)
Aerobatics get two short sentences, basically, "no restrictions, but be careful". Meanwhile, flying in cold weather gets a couple of pages, including a paragraph on Wheel Freeing that ends with "The consequence for landing with a locked wheel is not severe at most, a blown tire."
Anyone who has been around a 2-32 with a flat or blown tire knows how un-fun that can be!
Still my all time favorite Schweizer!
Kirk
66
Wanted: Flapped polar curve of a ventus ct Jurgen decraemer Soaring 2 December 9th 09 10:45 AM
Glass big learning curve? [email protected] Piloting 14 February 18th 07 09:44 PM
Discus polar curve at high speeds [email protected] Soaring 12 December 20th 05 02:59 AM
learning curve in fs 2002.. David Ciemny Simulators 5 December 30th 03 01:18 AM
18m polar curve Alan Irving Soaring 1 December 16th 03 12:45 AM
