91.205 compass requirement
Old April 17th 16, 06:45 PM posted to rec.aviation.soaring
Default 91.205 compass requirement
Does the ClearNav bearing display satisfy the magnetic compass requirement of FAR 91.205?
Old April 17th 16, 07:29 PM posted to rec.aviation.soaring
Tony[_5_]
91.205 does not apply to almost all gliders.
Old April 17th 16, 10:52 PM posted to rec.aviation.soaring
I could not find a FAR that exempted gliders. Can you point me to the correct FAR or FAA ruling?
Old April 17th 16, 10:59 PM posted to rec.aviation.soaring
2G
Try the title:
Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements
Old April 17th 16, 11:43 PM posted to rec.aviation.soaring
Bill T
Unless the glider manual or TCDS lists the compass as required.
Old April 18th 16, 01:26 AM posted to rec.aviation.soaring
MNLou
For what it's worth -
Almost none of the new gliders displayed at the convention had compasses.
I was told that was because the FSDOs had said that the GPS driven displays were adequate.
I understand there is "chapter and verse" for the regs supporting that but I don't know what it is.
Lou
Old April 19th 16, 02:38 AM posted to rec.aviation.soaring
2G
The question was "the magnetic compass requirement of FAR 91.205", not the POH. Clearly there is no such requirement for gliders.
Tom
Old April 19th 16, 08:10 AM posted to rec.aviation.soaring
How does 91.205 apply to self-launching gliders? Or to touring motor gliders?
Old April 19th 16, 06:53 PM posted to rec.aviation.soaring
JS
They are registered as gliders?
Old April 20th 16, 12:05 AM posted to rec.aviation.soaring
My motor glider is registered as a glider, Jim. But 91.205 does not use the word 'glider' it refers to 'Powered civil aircraft with standard category U.S. airworthiness certificates'. I have a self launcher, so would argue that although my glider is an aircraft, and is powered, the power is incidental to the flight, so its not a 'powered aircraft' as the FAA would define it. See also the FAA definition of a glider at the start of the FARs. I'm just guessing at the FAA's view here. But a touring motor glider might well be considered a 'powered aircraft' by the FAA, I'd guess, since its designed to cruise under power for a significant part of any flight.
Requirement of AW 139 pilot sanjay Rotorcraft 2 August 25th 08 10:06 AM
IFR Alternate Requirement gwengler Instrument Flight Rules 18 May 18th 05 02:26 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
CFI logging requirement [email protected] Owning 9 October 19th 04 07:11 PM
Mode S to become requirement? Bob Chilcoat Owning 6 July 14th 04 11:25 PM
