SURFACE PATCHING PASTE
Old July 4th 16, 10:16 PM posted to rec.aviation.soaring
ZZ
Default SURFACE PATCHING PASTE
I have always used Simtec's 4981 white patching paste to repair small dings and minor cosmetic divots. However I use such small amounts over long periods of time, nearly the entire quart eventually turns to rubber and has to be trashed.
I am looking for a lower quantity solution to avoid wasting so much material and cash. White is a must and MEKP catalyst is preferred but I am flexible on that.
Any suggestions?
Paul
ZZ
Old July 5th 16, 08:52 AM posted to rec.aviation.soaring
For very small dents, you could use cold enamel for repairing bathtubs, kitchen stoves etc. Available in small bottles (20 ml). Not really kosher, but...
http://www.ditmer.nl/EN/Enameling/Ca...old_enamel.htm
Old July 5th 16, 02:11 PM posted to rec.aviation.soaring
Papa3[_2_]
West Marine sells a patching paste. I have used it in the past for mid-season minor dings. With careful wet sanding and polishing it makes a pretty invisible repair.
http://www.westmarine.com/buy/west-m...-kit--14153282
Old July 5th 16, 07:26 PM posted to rec.aviation.soaring
CLewis95
Any suggestions?
Paul
ZZ
This looks interesting from West Marine:
http://www.westmarine.com/buy/west-s...04_120_001_508
Old July 5th 16, 08:32 PM posted to rec.aviation.soaring
Any suggestions?
Paul
ZZ
Good for your boat or trailer, but stick with the good stuff for glider repairs.
UH
Old July 5th 16, 08:44 PM posted to rec.aviation.soaring
Craig Funston
Any suggestions?
Paul
ZZ
You can extend the life of your 4981 by keeping it in the freezer. Best to let it warm a bit before opening so you don't get condensation in the can.
Craig
7Q
Old July 5th 16, 10:10 PM posted to rec.aviation.soaring
Steve Koerner
Seems like a business opportunity for someone who knows this stuff and can write...
Down package the good stuff to make a glider ding kit. Everyone gets little dings now and then. Quantities can be quite small to make the kit affordable. Include comprehensive instructions.
Europe surface-to-surface - File 16 of 25 - germany panzerfaust cutaway.jpg (1/1) Smaug Ichorfang Aviation Photos 0 October 28th 07 03:21 AM
Europe surface-to-surface - File 02 of 28 - england nlaw kestrel 0.jpg (1/1) Smaug Ichorfang Aviation Photos 0 October 27th 07 06:15 PM
Zink Chromate Paste Michael Horowitz Home Built 3 January 3rd 07 01:57 PM
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? jls Home Built 3 February 3rd 04 12:15 AM
best cutting fluid/oil/paste 2004..... theory and practice? B2431 Home Built 1 January 20th 04 06:27 PM
