Dg300 spar problem - sn
Old October 19th 16, 05:56 PM posted to rec.aviation.soaring
Default Dg300 spar problem - sn
Is it known which serial numbers actuallly had spar problem?
Conversely is it known which serial numbers were found to be ok after inspection?
A
Old October 19th 16, 10:02 PM posted to rec.aviation.soaring
The T/N and AD apply to all serial numbers. Elan didn't keep track of when they started deviating from the approved method of making the parts and substituted their own whimsical idea so the only way to find out is to open the wing up and look. By doing this you can tell if a particular DG300 has the spar problem or not but you can't tell by serial number.
The AD doesn't reduce the usability of the glider that much if so it probably isn't worthwhile cutting things apart for inspection to determine if a particular DG300 has a spar conforming to the original design or not. Might be worth looking around in there if you're already doing a serious wing repair as a result of an accident though.
Old October 20th 16, 02:43 PM posted to rec.aviation.soaring
Yes I know, but having this info might be an indication of since when this practice has been started by ELAN
S
Old October 21st 16, 06:02 AM posted to rec.aviation.soaring
S
Yes it would, but ELAN never kept track of when they started doing it. The only way to find out now would be to cut into every DG300 wing and see. Aside from the glider in which the defect was initially discovered I haven't heard of any other DG300 owner opening up their wings so we don't have a significant amount of data as to which gliders have been proven to have the problem.
Old October 21st 16, 09:25 AM posted to rec.aviation.soaring
Bruce Hoult
S
Assuming they simply started this construction technique at some point in time, and didn't start-stop-start it, you don't have to open EVERY wing.
If the wing of SN #N is opened for any reason and found to be ok, then you can assume that all lower SNs are ok too. Conversely, if it's not ok, then you can assume that all higher SNs are bad too.
Old October 21st 16, 10:25 AM posted to rec.aviation.soaring
Tango Whisky
No, you can't. If for some reason (end of shift, lunch break,...)there was more time between the epoxy filling and the lay-up of the spar cap, there wouldn't be any ondulations.
The only valid assumption is that all S/N's are affected.
Old October 20th 16, 02:58 PM posted to rec.aviation.soaring
Bruce Hoult
I hadn't previously been aware of this and was puzzled by this message. If anyone else is in the same situation, here is a description of the problem by our own Bob K from 2007:
http://www.hpaircraft.com/misc/dg300spars.htm
dg300 elan questions Christian de Vet Soaring 0 May 6th 11 04:04 PM
Got a problem with my wooden spar. Lou Home Built 3 June 4th 08 02:45 PM
Would you by DG300 ? [email protected] Soaring 9 October 8th 07 10:41 PM
DG300 horizontal stab. bolt saftey wire [email protected] Soaring 2 June 26th 07 04:35 PM
DG300 Tail weight John Schaffer Soaring 3 September 12th 06 10:36 AM
