Schweizer 1-34 Tail Tie Down?
Old November 15th 16, 09:09 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Schweizer 1-34 Tail Tie Down?
The manual is a bit vague on what fixture is used to tie down an SGS 1-34 tail. Almost every single seat Schweizer I can remember has some sort of eye bolt in the lower empennage area. What's the scoop with a 1-34? I'm not near the gliderport and the question came up in our club newsgroup.
p3
Old November 15th 16, 10:32 PM posted to rec.aviation.soaring
p3
Hole through the tail wheel bracket accepts tie down ring or bolt.
UH
Old November 16th 16, 12:44 AM posted to rec.aviation.soaring
Cookie
We had a NEW tail wheel bracket installed on that 1-34...there is no hole for a rope or bolt or anything...nobody has the heart to drill a hole into the new bracket...the mechanic didn't want to either...
Cookie
p3
UH
Old November 16th 16, 01:59 AM posted to rec.aviation.soaring
Cookie
p3
UH
Drill baby drill
UH
Old November 16th 16, 02:41 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Cookie
If you really don't want to drill a hole, how about a quick bit of outside the box thinking. Remove the axle bolt, take the tail wheel off, and put it in the cockpit. Put the axle bolt back in, and tie the rope around the axle bolt. No holes. Secured. May take an extra two minutes at the start and end of the day.
Just a thought...
Steve Leonard
Old November 16th 16, 02:59 PM posted to rec.aviation.soaring
Cookie
Just a thought...
Steve Leonard
Another alternative is to weld a ring to the head of the axle bolt, onto which the tie down can be looped.
Old November 16th 16, 10:58 PM posted to rec.aviation.soaring
JS
Cookie
Just a thought...
Steve Leonard
Perhaps going too far out of the box...
Chuck the rope around the tail boom?
Old November 17th 16, 07:23 AM posted to rec.aviation.soaring
kirk.stant
p3
Does your 1-34 have a trailer? Every 1-34 trailer setup I've seen uses a bolt through holes in the tailwheel bracket to hold down the tail on the trailer. Perhaps, load the fuselage on it's trailer and see if a tail lockdown bracket is present, and drill appropriate holes as required...
Think of them as "lightening holes"...
Kirk
66
Tail Wheels & Tail Booms snapp'n POPS Soaring 12 November 24th 11 02:00 AM
Tail Wheels & Tail Booms snapp'n db_sonic[_2_] Soaring 0 November 18th 11 08:35 PM
Schweizer TG-2 glidergeek Soaring 0 October 28th 11 01:34 AM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
FS: Schweizer 1-34, Schweizer Open Trailer F.L. Whiteley Soaring 2 April 10th 04 02:52 AM
